Author Topic: 70 Mach1 Steering Column Indicator Wiring  (Read 1103 times)
Offline Blown351stang
« on: October 10, 2018, 09:26:38 AM »
Can anyone tell me or have photo's on what way the indicator wiring runs down the steering column to the wiring plug bracket?
Will it be on the outside of the column to dash bracket , on the bottom under the bracket between the welded nuts on the column or on top between the column bracket and dash like the ignition wiring?
Re: 70 Mach1 Steering Column Indicator Wiring
« Reply #1 on: October 10, 2018, 08:00:48 PM »
With the lower trim in place its difficult or impossible to see the area your asking about so this is as close as possible I can provide at this time.  The electrical assembly manual might have a diagram with that detail
« Reply #2 on: October 21, 2018, 05:30:21 AM »
The electrical assembly manual was not that much help but the workshop manual helped a bit with the way you remove the indicator switch and the way my wiring wants to run.
« Last Edit: December 08, 2018, 06:34:00 PM by Blown351stang »
