Author Topic: 1966 sun visor  (Read 1078 times)
Offline socalgt
1966 sun visor
« on: October 08, 2018, 04:08:32 PM »
Did the sun visors originally have some type of plastic bushing or similar where the rod sits into the rear view mirror bracket?
Re: 1966 sun visor
« Reply #1 on: October 08, 2018, 04:16:58 PM »
yes. major vendors sell them.
Offline NEFaurora
Re: 1966 sun visor
« Reply #2 on: October 09, 2018, 05:50:02 PM »
Yes, There were Two separate types.  The '64-'66 ? Early one that had a Hole going thru the entire piece and was White....and then there was the Later Gray one that was more like an "Endcap" design. from '66 to '70...and perhaps used even later.
I believe that Virginia Classic Mustang (VCM) carries both.
The Early one here:
http://www.virginiaclassicmustang.com/64-12-65-SUNVISOR-TIPS-OPEN-ENDED-STYLE-PAIR-P85592.aspx
The Later one here:
http://www.virginiaclassicmustang.com/SUNVISOR-TIP-STANDARD-CLOSED-END-STYLE-EACH-P4527.aspx
:o)
Tony K.
« Last Edit: October 09, 2018, 05:54:21 PM by NEFaurora »
MCA#70001
Re: 1966 sun visor
« Reply #3 on: October 09, 2018, 06:06:48 PM »
For the OP's question the closed end one would be the original style. Just so the readers don't get confused with "extra" details ;)
Though he didn't provide the plant and when the car was built I found San Jose April 66 in one of the prior posts :)
« Last Edit: October 09, 2018, 06:09:39 PM by J_Speegle »
Offline mgmradio
Re: 1966 sun visor
« Reply #4 on: October 10, 2018, 10:26:46 PM »
Actually the open ended style was only used on the 64.5 and early 65's. The closed end style seems to have started around February or March 65 or earlier.
Offline rocket289k
Re: 1966 sun visor
« Reply #5 on: October 11, 2018, 01:23:46 PM »
+1 - my late July 1965 Metuchen build was the closed end style
Offline NEFaurora
Re: 1966 sun visor
« Reply #6 on: October 13, 2018, 11:50:18 PM »
This has nothing to do with correctness, but I've found that the Earlier White type ones seems to work/fit better.  The later Grey type can slide off sometimes and they tend to crack after a few years requiring replacement.
Just an observation..
:o)
Tony K.
MCA#70001
