Author Topic: Still looking: W MO radiator for '67 small block w/C4  (Read 457 times)
Offline Deuce
« on: October 05, 2018, 11:28:37 AM »
1967 C-code coupe (San Jose Nov 66 Build date) with C4, AC and Thermactor has a replacement Modine radiator installed in the early 1980s.  Aside from the replacement radiator, the car's cooling, AC and Thermactor system groupings are complete and functioning; e.g., 7-blade clutch C6OE-G fan, C7ZE-8146-B (FoMoCo block logo) fan shroud, correct hot water valve, etc.
Seeking an original 20 in. W MO radiator (or top tank) with date code of 10-66 or 11-66.
« Last Edit: October 05, 2018, 11:08:58 PM by Deuce »
Deuce
Re: Still looking: W MO radiator for '67 small block w/C4
« Reply #1 on: October 05, 2018, 07:34:38 PM »
+1
I could use a C7 shroud too and will accept Aug thru October but if you have October date, Robert has first dibs ;)
Offline Deuce
« Reply #2 on: October 05, 2018, 09:08:47 PM »
Good to hear from you Richard.  My car is a 30 Nov 66 actual build date (6 Dec scheduled build date), so I suppose I could widen the W MO radiator date range, all the way back to Sep (9-66) or Aug (8-66); although Aug might be a stretch.
Robert
Deuce
