Author Topic: Top loader 4 speed. RUG AV Worth?  (Read 5370 times)
Re: Top loader 4 speed. WIW
« Reply #15 on: October 18, 2018, 11:01:38 PM »
  It does.   06846.  That's all of it.
Having a second didgit of a "0" eliminates the possibility of it coming out of a Cougar or Mercury doesn't it Mike?
For a Mustang it would be 0xxxx106846  or 0xxxx206846 if it's out of a 70. Does it have a number on the bottom line of the transmission tag?
Sorry if your getting in the weeds in relationship to your original "whats it worth" question.
Offline CCP
Re: Top loader 4 speed. RUG AV Worth?
« Reply #16 on: October 19, 2018, 09:05:57 AM »
  Not at all. The number on the bottom of the RUG tag is  011212.
 I would love to see the trans reunited with the car if it still exists.
                                          Pete.
1969 Fairlane Cobra formal roof drag pack
1968 Shelby GT500KR
6F08A-GT,a/c,4-sp.,ps,build date 16A. DSO 24 Jacksonville
« Reply #17 on: October 19, 2018, 06:41:27 PM »
That only helps narrow down when the car it came from could have been built. Looking at my  records I find a RUG-AW with a transmission serial number (011180) close to that was that build on Sept 25th with a vin of  0F1096xx. So 1300 units (transmissions built) after this example. Of course due to need transmissions were not installed or used in sequential order. Have one with a lower trans serial number (different application) installed months after this example but again it was a different application and not a AV.
No smoking gun but rather narrowing the range
Offline Mike_B_SVT
« Reply #18 on: November 06, 2018, 07:43:44 PM »
Nah, if it were from a Cougar / Mercury it could still have been something like  0xxxx506846.  Would have had a Sept '69 build date.
Could always submit it to Marti for research, but
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline rcgt350
« Reply #19 on: February 23, 2019, 01:50:12 AM »
So is a Wide Ratio’s 1st to 2nd closer together than the Close Ratio? And then the rest of the gears are wider apart than a Close Ratio?
1967 GT 350 W White
1970 Boss 302 GG Restoration in progress
2012 Boss 302 C Orange
1930 Ford Model A 4 Door Deluxe Town Sedan
Offline 70cj428
« Reply #20 on: February 23, 2019, 01:08:47 PM »
Quote
Wide Ratio-
2.78 1st, 1.93 2nd, 1.36 3rd, 1.00 4th
Close Ratio-
2.32 1st, 1.67 2nd, 1.29 3rd, 1.00 4th
Your engine speed will drop less with a close ratio box on every shift. This helps keep the RPM's in the power band when shifting. Unfortunately, 1 st gear on a close ratio box isn't as low as a wide ratio box, so getting the car moving from a standing start is harder. You can make up for this by changing to a steeper rear gear but then your engine speeds on the highway are higher and you theoretical top speed will drop.
Modern cars remedy this situation with an extra overdrive gear ...
Since Boss 302's don't make a lot of torque at lower engine speeds, a wide ratio box makes them a whole lot nicer to drive, especially if your car was built with a 3.50 / 1  rear gear ...
Hope this helps, John
« Reply #21 on: February 23, 2019, 04:42:57 PM »
« Last Edit: February 23, 2019, 05:33:23 PM by Bossbill »
