Author Topic: 1970 Rear Tie Down Brackets  (Read 1345 times)
Offline 1970 Snake
« on: October 02, 2018, 12:42:05 AM »
I would like to know if it is a bad idea to install the rear tie down brackets on my Dearborn built 1970 Mach 1 with dual exhaust as part of the restoration, or is it frond on by the judges?? Pro's: car is easily tied down if trailered, Con's: may interfere with springs and exhaust (mine do not), they do stick down below the exhaust and springs and are visible from the rear and side view of the car kind of ruining the blackout effect on the trunk drop pinch weld as 1970 are bare metal color. I understand NOT ALL where removed at the dealer. Also did only the 69 cars have the removal sticker on the license plate bracket or did the 70's also have the sticker.
« Last Edit: October 02, 2018, 12:48:50 AM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: 1970 Rear Tie Down Brackets
« Reply #1 on: October 02, 2018, 03:01:08 AM »
Ether way is fine and most Judges don't give a second thought with the caveat of if you chose to not install them the place where they were normally installed should have signs that something was there but taken off like scuff paint from bracket and bolts etc. That look is what would be expected when a dealer worker took them off during pre inspection back in the day.
Offline 1970 Snake
« Reply #2 on: October 02, 2018, 08:34:21 AM »
Much appreciated thanks Bob, and yes I was thinking the same thing about the marks on the paint. I see Marcus A. in his website article on these brackets shows a 1969 bulletin from Ford regarding removal by the Dealer and placed the license plate bracket sticker at the factory on the cars regarding same. Do you know if the same sticker was placed on the 1970 Dearborn cars with dual exhausts or was it only the 69 cars?
« Last Edit: October 02, 2018, 08:37:40 AM by 1970 Snake »
« Reply #3 on: October 02, 2018, 12:06:26 PM »
My expertise is spotty after 1969 Dearborn cars given the Shelby cars I focus on. It probably was but I am not 100% sure the exact same sticker was used so I was hoping that Jeff Speegle would have some evidence in his picture collection.
Offline cobrajet_carl
« Reply #4 on: October 02, 2018, 01:40:31 PM »
Two of my 428 cars still have remnants of the original sticker. October and November Dearborn.
Carl
70 and 71 Dearborn mach Is
Offline 1970 Snake
« Reply #5 on: October 02, 2018, 02:09:50 PM »
Am assuming that is Oct/Nov 1969?? Mine is a 428 R-code built Sept 1969.
Can you tell if its the same sticker that's on the 1969 year models??
Offline 7Lscjracer
« Reply #6 on: October 02, 2018, 10:50:07 PM »
All Carl's cars are 0F or 1F so that's a safe bet.
I believe the sticker is the same for 65-73.
No "part" number on them, and looking at it logically, what reason would there be to change the sticker?
Here's a 73 car example:
http://www.oldcarsweekly.com/blogs/under-the-hood/37-mile-1973-ford-mustang-convertible-offers-rare-view-to-past
Bought May '81, sold Sept '20
Offline 1970 Snake
« Reply #7 on: October 02, 2018, 11:46:20 PM »
Thanks for the update and pics.
« Reply #8 on: October 03, 2018, 06:32:34 PM »
Been out for a couple days but there are examples of at least one Dearborn 70 and the tie down decal/sticker in the unrestored picture threads.
Offline 1970 Snake
« Reply #9 on: October 03, 2018, 07:12:22 PM »
Thanks Jeff, yes there is one picture, will do the sticker install accordingly.
