Author Topic: 64.5 P/S pump pulley dimensions  (Read 1105 times)
Offline midnite cruiser
  • midnite cruiser
« on: September 27, 2018, 03:08:45 PM »
Shopping for this I have been asked the pulley diameter and offset.
Could someone out there measure theirs? This is a D code with both P/S and A/C
JWhite
64.5 D code convert. / C4 / AC / PS / RP
Offline ChrisV289
Re: 64.5 P/S pump pulley dimensions
« Reply #1 on: September 27, 2018, 03:18:01 PM »
Remote reservoir or is it using the special brackets to sit lower to clear the compressor?
2009 V6 Mustang Coupe
Online jwc66k
« Reply #2 on: September 27, 2018, 04:38:34 PM »
Did you look in this Forum's Library?
  • midnite cruiser
« Reply #3 on: September 28, 2018, 12:14:23 PM »
Looking through the library I see data on crankshaft and water pump pulleys only.
Convert has A/C and P/S with the remote silver top fender mount reservoir
pre-disassembly pix
JWhite
  • midnite cruiser
« Reply #4 on: October 25, 2018, 06:21:17 PM »
Still would appreciate a member taking a quick tape measure on their Eaton pump pulley
JWhite
« Reply #5 on: October 25, 2018, 10:22:34 PM »
I don't have my book handy, but would highly recommend picking up a copy for your reference library:
www.fordsmallblock.com
It has the info you're looking for and much more.
  • midnite cruiser
« Reply #6 on: October 26, 2018, 05:44:44 PM »
I have that book. Will keep digging.
JWhite
Offline Chris
« Reply #7 on: October 29, 2018, 04:27:21 PM »
Mine is a 260 with A/C and power steering, same unique compressor bracket with remote P/S reservoir. I’ll post some pics. My pulley is a different type, they were not all the same, the differences are listed in Bob Mannel’s book in the back. I’ll look up the info for the type bracket you have shown.
Offline Chris
« Reply #8 on: October 29, 2018, 09:07:22 PM »
From looking at the pulley tables in Mannel’s book, appendix B-20, the power steering pulley that you show in the picture looks to be an A/C magnetic clutch matted to a York compressor. The three predominant manufacturers for 64-66 were Pitts, Warner, and Eaton. I can’t see the face of the pulley to make a positive ID, but it looks to be a Pitts magnetic clutch pulley, this was the primary clutch used in 1964.
The info is:
Part number: C4OZ-2884-A
ID number: C4OA-2981-A
Depth: 1.4
Diameter: 6.8
Offline ChrisV289
« Reply #9 on: October 29, 2018, 09:23:08 PM »
I think he is wanting the diameter of the power steering pulley not the AC clutch.  Mine is over 5 inches but is a different set up.
Offline Chris
« Reply #10 on: October 29, 2018, 09:32:31 PM »
Sorry, moving too fast. Let me try again.
Offline Chris
« Reply #11 on: October 29, 2018, 10:06:26 PM »
Ok, here is the power steering pully info. I measured mine and it’d 4 6/16 inches across. The book says the Eaton power steering pulley diameter for 64 is 4.4 inches, so that’s about right. The pics are attached.
« Last Edit: October 30, 2018, 08:23:27 PM by Chris »
