Author Topic: 1964.5 Frame Cut-Out for Tire? Is this correct?  (Read 911 times)
Offline RAH2 1964.5
« on: September 24, 2018, 05:18:52 PM »
The frame of my 1964.5 Convertible has a cut-out per the pics attached. Is this correct? Is this for tire clearance?
Thanks Roger
05/08/64, Dearborn, Convert., DSO Phil.
Raven, Stand. Int., White with Black Trim
AT, 260v, PS, Console
2003 Cobra Convert., Torch Red, 10th Anniv., Stock
2006 GT Coupe, Redfire, Factory Stripes, Stock (Shaker Intake)
Re: 1964.5 Frame Cut-Out for Tire? Is this correct?
« Reply #1 on: September 24, 2018, 05:20:54 PM »
yep. you have discovered another early car anomaly.....keep digging there are more.
Offline RAH2 1964.5
« Reply #2 on: September 24, 2018, 05:31:15 PM »
The tire still rubs. Working on that.
Thanks Roger
Offline NEFaurora
« Reply #3 on: September 27, 2018, 10:31:33 PM »
"yep. you have discovered another early car anomaly.....keep digging there are more."
It's not an "Early Car Anomaly".... My Late production '65 and my '66 both have the same identical "Cut-Outs"....
The "Cut-Outs" are for the Brakes hoses.....so that the Brake Hoses don't get crushed by the Tire against the Uni-Body Frame...
I believe that "Really Early" cars don't have the cut-outs.... Like Dearborn Mustang#1  VIN# 100001 ..... No Cut-outs on that car...
Others will chime in to comment...
:o)
Tony K.
« Last Edit: September 27, 2018, 10:42:29 PM by NEFaurora »
MCA#70001
« Reply #4 on: September 27, 2018, 11:17:59 PM »
The frame of my 1964.5 Convertible has a cut-out per the pics attached. Is this correct? .......
After looking at other examples a car in the 5F14xxxx period IMHO yes it's correct. And would be present on both sides
Earliest car I have (lowest VIN) with this detail that I have pictures of would be 5F100037
Offline NEFaurora
« Reply #5 on: September 30, 2018, 12:47:18 AM »
"Earliest car I have (lowest VIN) with this detail that I have pictures of would be 5F100037"
Great info.   I did'nt realize that they had even started that early with the "Cut-Outs"....even in Pre-Production.... It looks like someone realized the Possible issue real early!
:o)
Tony K.
MCA#70001
« Reply #6 on: September 30, 2018, 02:11:16 AM »
I don't know about labeling 5F100037 as "pre-production" since they were producing the cars  ::)  I sort of save that term for the pilot plant cars :)  But that's what I found but would love to see others from the first couple of days of production to back up the finding as always
