Author Topic: 67 Exterior Decor Group  (Read 3646 times)
« on: September 17, 2018, 04:48:50 PM »
While constructing the 67 GT Equipment Group thread, John reminded me that the "Exterior Decor Group" option has many features that people confuse with the "GT Equipment Group" option.
These are noted in the following chart. Be aware that the term "Base" indicates the starting point for the option, not a "basic car".
Any Mustang, regardless of engine, could have the "Exterior Decor Group" option.
Vehicle without GT Option Group
Package                Fuel CapHood  Wheel Openings    Trunk/Cap molding
Base -- any Model     Twist-Open
Mustang Logo
FlatBareBare1
Add Exterior Decor
Group
Pop-Open
Mustang Logo
Louvered
Turn Signal
Bright MoldingsBright Moldings1
Vehicles With GT Option
Base -- Any Model
with GT Option
Twist-Open
GT Logo
FlatBareBare1
Add Exterior Decor
 Group
Pop-Open
GT Logo
Louvered
Turn Signal
1) 2+2 model has Trunk and Rear Cap Bright Moldings as standard equipment and is not affected by GT or Exterior Decor Group options.
Additionally, the option "Lower Back Panel Grille" was contingent on the "Exterior Dcor Group" option. It could not be ordered alone.
[Rev 1 to remove back panel grill. Rev 2 to simplify chart.]
« Last Edit: September 18, 2018, 04:11:20 PM by Bossbill »
Offline 427Fastback
Re: 67 Exterior Decor Group
« Reply #1 on: September 18, 2018, 12:25:49 AM »
OK....so maybe I am reading it wrong ....what option then put the rear finned taillight panel on a coupe ???
« Reply #2 on: September 18, 2018, 06:21:39 AM »
The lower back panel grille was a separate, stand alone option, not part of the exterior décor group option.
« Reply #3 on: September 18, 2018, 08:59:15 AM »
Bill, anything to add to this one?
I have a basic understanding but I think my understanding is tainted by poor samples WITHOUT confirmed Marti Reports or build sheets...I wonder if it was a "by itself" "stand alone" or if it required other "basics" in place to be added in a vehicle order form.
Offline gtamustang
  • CPM
« Reply #4 on: September 18, 2018, 09:23:48 AM »
This is correct. There were two styles of the back panel grille: painted a dark gray, represented by a two digit paint code on the warranty tag (I do not have the color code) and painted body color. As Jeff has found there are known examples of the two digit paint code without the back panel grille. Interestingly, when the dark gray was applied, the panels were in place, thus the tail light panel behind the back  panel grilles was the original body color.
Regards,
Pete Morgan
« Reply #5 on: September 18, 2018, 09:36:22 AM »
The "lower back panel grille" was a stand alone option for all three models - coupe/vert/2+2.
The "two tone paint" was also a stand alone option, a "dark gray poly" that as Pete mentioned results in a two digit paint code (first digit the body color, second digit being a 5 representing the gray.  For example Q5 would be Brittany Blue with the two tone option.
These options could of course be ordered on the same vehicle.
The exterior décor option is yet again separate and not related to or affected by the lower back panel grille and/or two tone paint options.
That said, if the two tone paint was ordered on a coupe/vert without exterior décor, they would have an issue with the missing bright rear trim.  So that would have to be included.  Either that or exterior décor was required for the two tone paint (but I have never seen that requirement stated anywhere.) These things can get complicated!
Here are three related links on this subject:
http://www.concoursmustang.com/forum/index.php?topic=1219.msg6168#msg6168
http://www.concoursmustang.com/forum/index.php?topic=8085.msg46714#msg46714
http://www.concoursmustang.com/forum/index.php?topic=168.msg731#msg731
« Last Edit: September 18, 2018, 09:46:39 AM by 67gta289 »
« Reply #6 on: September 18, 2018, 01:46:37 PM »
Sorry, I appear to be at the mercy of conflicting documentation.
I keep two versions of the 67 Illustrated Facts and Specifications Manual.
While waiting for my DP to harden I wrote this post using the shop version of the booklet, the White Cover version offered by Jim Osborn "MP294".
It lists the "Custom Exterior Trim Group" with the last sentence as "... on Hardtop and Convertible, plus lower back panel grille on 2+2 fastback."
The Blue cover version of the same booklet I have in the study, but by Mustang Monthly Magazine, strips off the portion of the sentence after the comma.
I've never seen many GTs with the rear grill and doubted the veracity of the White Cover version. Sloppy reporting on my part.
I'll update my first post.
By the way, $19.48 for the back panel grill in 1967 is $145.97 in today's money.
« Last Edit: September 18, 2018, 01:57:10 PM by Bossbill »
Offline 196667Bob
« Reply #7 on: September 18, 2018, 02:26:52 PM »
+1 as supported by Sales Brochures, 1967 Showroom Options Book, and Salesman's Price Guides.
Accordingly, Bossbill's listing of Exterior Décor contents should be revised to show that the "Rear Grill" (or "Grill, Lower Back Panel"), both Ford designations, was a separate Option, only available if the "Exterior Décor" Option was also ordered.
FYI, Ford's actual part designation in the 1960-68 MPC is "Panel Assembly - Lower Back Applique". Part Numbers for Fastbacks is C7ZZ-6340584/85-A, and for Coupes and Convertibles C7ZZ-6540584/85-A.
Bob
MCA 04909
« Reply #8 on: September 18, 2018, 02:40:21 PM »
Bob
This is my understanding on the rear grille panel at this time, willing to update my view as CONFIRMED evidence proves otherwise.
