Author Topic: 70 Mach1 Dash Courtesy Light Position  (Read 1786 times)
Offline Blown351stang
« on: September 16, 2018, 06:42:04 AM »
Has any one with a 70 Mach1 with A/C got some picture of where the factory 70 dash courtesy light is mounted on the dash? Mainly on the passengers side my one has a hole for one but the light hits the heater box.
I am thinking it should be closer to the outside glove box door hinge bolts.
The drivers side one is right I think just above the brake release lever.
Re: 70 Mach1 Dash Courtesy Light Position
« Reply #1 on: September 16, 2018, 08:55:07 AM »
I may be wrong, but I think your courtesy lamp in the first picture is upside down from what it should be.
« Reply #2 on: September 16, 2018, 06:22:08 PM »
Nope your correct. But his way will help out if your working on the back side of the dash assembly though bulbs do get might hot :)
Not sure if the location changes for AC cars but will continue to look for a picture. Not allot or people taking pictures of this detail
Non-AC example
« Reply #3 on: September 17, 2018, 09:06:23 AM »
Easily fixed ;D. It was hitting the brake release lever but I may just need to bend the bracket to clear it.
As for the passenger light I don't seem to have a hole in that spot but thats really the only place it fits and clears the heater box. I'd say some one replace that part of the dash for some reason.
« Reply #4 on: September 17, 2018, 06:01:11 PM »
If they did it would have been from another car and (if it were so) that car would have had a hole there also unless AC cars are different or a 69 is not the same (underdash lights mounted in a different location
« Reply #5 on: October 21, 2018, 06:50:45 AM »
The hole is in the glove box door hinge the dash just has a big hole in that spot it must of had a hinge replaced.
