Author Topic: Fuel Line Retaining Bracket at front of a Fall 64 289  (Read 1397 times)
Offline 66RavenGTCoupeAgain
« on: September 10, 2018, 09:28:30 PM »
Hey guys,
Would this be the correct fuel line bracket for this date and plant?
ADMIN NOTE: This thread was separated from a different thread focusing on an unrestored  Oct 64 San Jose built fastback
« Last Edit: September 12, 2018, 02:10:07 PM by J_Speegle »
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: Fuel Line Retaining Bracket at front of a Fall 64 289
« Reply #1 on: September 10, 2018, 09:31:26 PM »
Hey guys,
Yes  Shouldn't answer questions after getting home following a long airplane flight  ::)  Thanks Chris
66Raven this is the correct style
« Last Edit: September 11, 2018, 05:43:13 PM by J_Speegle »
Offline ChrisV289
« Reply #2 on: September 11, 2018, 10:23:23 AM »
Hey guys,
That's a 66 clamp....
2009 V6 Mustang Coupe
« Reply #3 on: September 11, 2018, 08:54:01 PM »
Thanks guys!
« Reply #4 on: September 12, 2018, 08:27:06 AM »
So is this mounted on the head? Anyone have a pic of how its mounted and with what hardware please?
« Reply #5 on: September 12, 2018, 02:30:16 PM »
Bolt appears to just be another one of the timing cover bolts used around the face of the timing cover to engine edge
« Reply #6 on: September 13, 2018, 07:48:47 PM »
Oh great thanks. Sorry but it had me confused because I felt that the little "leg" near the brackets mounting hole was there to align it some how but it seems to not have a function at all. Great photos. Much appreciated.
Offline ChrisV289
« Reply #7 on: September 14, 2018, 12:38:10 AM »
Remember the bottom portion of the bracket will be painted black as it was installed when the block was painted.  The securing top portion and screw are unpainted
« Reply #8 on: September 14, 2018, 01:36:53 AM »
Guess it might be best to describe it as the bracket was attached to the rest of the engine when it was painted so it was fully painted along with the mounting bolt. The fuel line and retaining clip were installed alter so they are not painted engine black ;)
« Reply #9 on: September 17, 2018, 09:14:50 PM »
Got it. Great. Thanks Chris and Jeff. It seems that in all of these pictures the fuel line is routed behind the distributer. Was this a hard and fast thing or were both routes used at this time and plant?
« Reply #10 on: September 17, 2018, 09:20:14 PM »
............. It seems that in all of these pictures the fuel line is routed behind the distributer. Was this a hard and fast thing or were both routes used at this time and plant?
From the examples we have that is how the workers at the engine plant was routing them at that time. These were preformed so the workers were not bending them any way they wanted - they just installed what they were provided with
« Reply #11 on: September 17, 2018, 11:01:19 PM »
Thanks Jeff, I suppose what I was asking was which route is correct for this time and plant or are they both correct?
Offline ChrisV289
« Reply #12 on: September 17, 2018, 11:48:41 PM »
I believe it should be routed behind the distributor...
« Reply #13 on: September 18, 2018, 12:02:10 AM »
Sorry thought you were asking for confirmation of your statement in reply #9 and if they could have come either way
Yes the ones posted (in many you can see the turn towards the carb before the dist) confirm that that was the routing used at this time period
