Now moving to the inside of the trunk. What I found was an inconsistent pattern around the mounting bolts. Some with a fairly even amount around the washer, most with an inconsistent bead and some with no visible sealant. My conclusion at this time is that on some cars the sealant was introduced (a little or allot) through the mounting holes and as the washer rotated during the install (if it did) it spread out the sealant and distributed some in a fairly even amount, on those where they didn't we ended up with more sealant on one side or area and on cars where not allot of sealant was pushed through there was not enough to squeeze from the center to the outer rim of the washer to show anything. But bottom line there was no premade washer or disc of sealant applied to the back side of the mounting washers or what we would be seeing would be much different at this plant and this year.
Examples
E-1 5RT09C1508xx. Only a small amount on the top edge
E-2 Same car as above No sealant on the top edge
E-3 5R07C1670xx Appears to be no sealer visible at either hole/point shown
E-4 5R08C1817xx Just about nothing at the bumper guard Uneven around both bumper bracket bolts
E-5 Same car as above
E-6 5R07T1874xx In this case what looks to be a nice even bead of sealant around the inner mounting bolt at least at the top edge
E-7 On the same car as above. Looks like little to no sealant on inner bumper bolt on the drivers side but nice large amount of sealant around bumper guard bolt at least on the top half
E-8 Same example - different angle
E-9 5R09K201xx No visible sealant around the two bumper bracket holes
E-10Same car as above
E-11 5R07A2094xx Inner passenger side bolt is maybe 60/40 sealant
E-12 Same car - Drivers side. No visible sealant around the inner and bumper guard mounting bolts. Outer bolt as some but not allot
5R07A22724xx Some around bumper bracket bolt - none at bumper guard
Have more but choose ones that were clearer for this pass through
