Author Topic: Where Do I find 13/16 Sway Bar rubber Bushings ??  (Read 1953 times)
Offline Boss980
« on: August 18, 2018, 12:04:30 PM »
For my 69 351w GT Mustang Where do I find the Sway Bar Bushings 13/16 in rubber to go with the stock brackets?
All I can find are the ones that are Polyurethane, Any Help
Offline preaction
Re: Where Do I find 13/16 Sway Bar rubber Bushings ??
« Reply #1 on: August 18, 2018, 01:07:56 PM »
National Parts Depot
1967 eight barrel
  • Guest
« Reply #2 on: August 18, 2018, 03:07:37 PM »
NPD has reproductions in black rubber. You have the common bar size.
                                                             -Keith
Offline Boss980
« Reply #3 on: August 18, 2018, 03:23:47 PM »
Sorry guys I see every size but the 13/16" on NPD do you happen to have a part number?
1967 eight barrel
  • Guest
« Reply #4 on: August 18, 2018, 04:44:17 PM »
I assume these are for the front? If memory serves me it would be 3/4".
        -Keith
Offline Boss980
« Reply #5 on: August 18, 2018, 10:37:20 PM »
Yes this is for the front 69 Mustang 351w GT but its defiantly bigger bar then a 3/4 and measures exactly 13/16
I tried a 7/8 bushing but it was to sloppy, So your saying I should use a 3/4 bushing for this ??
« Last Edit: August 18, 2018, 10:45:31 PM by Boss980 »
« Reply #6 on: August 18, 2018, 10:58:34 PM »
The 15/16 bar was used on the Boss 302, 69 GT350 ,GT500 among other high performance Mustang based cars in 69 . I am skeptical of 13/16 bar if factory Ford ,maybe 15/16 instead?
« Reply #7 on: August 18, 2018, 11:29:45 PM »
The Boss 302 used a number of different front sway bars depending on when they were built but that is not the focus of the issue here.
For a non- Mach I fastback with a 351W the parts books show a 11/16th size bar and a 7/8th bar
« Reply #8 on: August 19, 2018, 12:08:50 AM »
Jeff , the point I was making was that ether the larger bar is a replacement or it could be a 15/16 like what was used in other high performance Mustang models . After market bars were typically 1 inch in diameter.
Offline Boss980
« Reply #9 on: August 19, 2018, 08:19:20 AM »
Thanks for the reply's, It does measure 13/16 but either its an after market bar or 7/8 is the correct bushing and its just sloppy by nature?? Might just swap out the bar for one that I know it's source
I appreciate the info
« Last Edit: August 20, 2018, 08:27:49 AM by Boss980 »
Offline 7Lscjracer
« Reply #10 on: August 19, 2018, 11:42:36 AM »
I will measure the bar on my M code 69 Mach 1 when I'm back in town
with an open end wrench
I know it's an original
Bought May '81, sold Sept '20
Offline Boss980
« Reply #11 on: August 21, 2018, 09:31:17 PM »
A question about this bushing in the bracket, Is it correct that the bushing is taller then the bracket??
The new bushing fits nicely in the stock bracket but as you can see it has a tapered end on it that extends beyond the bracket by about 1/4 inch It would seems that when I bolt the bracket to the frame it would squish the bushing
or am I missing something here??
Any help appreciated
Offline 7Lscjracer
« Reply #12 on: August 24, 2018, 01:06:51 AM »
The 13/16 wrench was no go, the 7/8 was go over the bar.
As you can see, original bushings protrude substantially.
Offline Boss980
« Reply #13 on: August 24, 2018, 09:59:45 AM »
Thanks for the pics, So this is a picture of my bushing and bracket against the frame, Does this look correct?
So what am I missing here ?
Appreciate your feedback?
« Reply #14 on: August 24, 2018, 11:37:32 AM »
The brackets were bare metal and not black originally.
