Author Topic: 1964 1/2 V8 Differential Color  (Read 634 times)
Offline RAH2 1964.5
« on: August 07, 2018, 04:48:03 PM »
I am tying to determine the correct color for the rear differential for my 1964.5 Convert. v.260 F Code. The MCA Rules say black. I have seen the pumpkin red. Also, some of the parts remained steel. I searched index  but saw nothing on point.
« Last Edit: August 07, 2018, 06:38:01 PM by J_Speegle »
Thanks Roger
05/08/64, Dearborn, Convert., DSO Phil.
Raven, Stand. Int., White with Black Trim
AT, 260v, PS, Console
2003 Cobra Convert., Torch Red, 10th Anniv., Stock
2006 GT Coupe, Redfire, Factory Stripes, Stock (Shaker Intake)
Re: 1964 1/2 V8 Differential Color
« Reply #1 on: August 07, 2018, 06:37:23 PM »
Short answer is
1- Rear end housing is painted semi-gloss black with natural front surface where the 3rd member would attach.
2- Third member/carrier was painted with a red oxide colored epoxy primer prior to machining.
3- Pinion retainer painted with a red oxide colored epoxy primer prior to machining. Visible freshly machined surfaces on exterior
4- Pinion retainer bolts were a dark heat treated natural/bare finish
5- 3rd member retaining nuts were cad but a dull zinc may look similar. Copper washers installed under the buts on the lower half +  nuts
6- Yoke bare cast iron with fresh machined surfaces
7- Pinion seal shield/washer. Bare stamped steel
Found these using the search feature - similar in some details
http://www.concoursmustang.com/forum/index.php?topic=8550.msg49644#msg49644
http://www.concoursmustang.com/forum/index.php?topic=16578.15
« Last Edit: August 07, 2018, 06:47:28 PM by J_Speegle »
Offline RAH2 1964.5
« Reply #2 on: August 07, 2018, 06:54:02 PM »
Thank you Jeff. I am learning how to search the index. Still, I wasn't sure because so many of the information I found often dealt with Hi-Po's and the like rather than a base v260 V8.
Thanks Roger
« Reply #3 on: August 07, 2018, 06:57:17 PM »
.............Still, I wasn't sure because so many of the information I found often dealt with Hi-Po's and the like rather than a base v260 V8.
No problem - though allot of members have K codes or later cars with 9" rear ends, six cylinders and other engines are also represented, discussed and posted here also.
