Author Topic: Oiling PO bolts as a preventative measure  (Read 3289 times)
Offline 67350#1242
Re: Oiling PO bolts as a preventative measure
« Reply #15 on: August 07, 2018, 04:25:58 PM »
As long as the original phosphate coating remains you may rejuvenate the look by oiling or with Boeshield. Sometimes the coating will get a tinge of rusty color over time and may be leaching up thru the phosphate. If not too extreme can be flushed out with oil and the dark color will return.   Have done this with hinges.
Kurt.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline Hipo giddyup
« Reply #16 on: August 10, 2018, 10:59:18 AM »
Thanks for all the info. I will post what my bolts look like in their current state and the new bolts once treated with Boeshield. Also, the STAR washer bolts that were used elsewhere under the hood have not turned rust color like the flat washer bolts. Strange, I'll post pics for that as well.
« Reply #17 on: August 14, 2018, 12:07:41 PM »
I have been following along and reading with some interest what you fella's are suggesting, using and doing.  For myself I asked Jim to P & O some already sand blasted parts for me two years ago.  Those parts from my 69 are the hood hinges w/springs, the shock tower caps including attaching nuts and bolts and the coil bracket.  I have found that with a Boeshield T9 application every two month's or so seems to retain the finish.  My experience is that the P & O finish is not permanent or long lasting and requires at least some attention and care.  The Boeshield application using a 1" brush and a small rag and 10 minutes is all it takes.  Before 6/10/16 and now 8/14/18 photos appears about the same ?  Brian
« Reply #18 on: August 14, 2018, 01:40:24 PM »
Brian,
Thanks for the pictorial feedback.
Offline bhoulis
  • 67 GT350
« Reply #19 on: August 22, 2018, 09:21:03 PM »
++Boeshield. Like the ad for Franks Red Hot Sauce, "I put that sh-t on everything!"
Brian
