Author Topic: Hot Idle Compensator  (Read 6848 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: October 07, 2010, 08:49:30 PM »
On a 66 C-Code,  what is the function of the Hot Idle Compensator, in the PCV hose to the carb spacer on A/C equipped cars?
How does it work?
Is it just basically an intentional vacuum leak that opens and closes depending on engine bay temps?
I guess that would cause 2 idle speeds if open or closed?
66 Metuch Conv
Nightmist, Std Blu Int
Re: Hot Idle Compensator
« Reply #1 on: October 07, 2010, 09:39:30 PM »
Believe you have a decent general understanding of the principles. Engine compartment temp changes, valve opens or closes and in turn effects the idle, keeping the engine running through these temperature changes
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: October 07, 2010, 10:00:11 PM »
Thanks Jeff,
So I thought it was either on or off, but based on your description, it's propotional to temperature, right?
66 Metuch Conv
Offline Murf
« Reply #3 on: October 08, 2010, 12:24:08 AM »
When the ambient underhood temp increases to a certain point the bi-metalic strip on the hot idle compensator opens a rubber needle - brass seat metered orifice, causing what is essentially a vacuum leak of a predetermined amount into the intake system.  This extra air will in turn cause the idle speed to increase, moving more air through the radiator and water through the cooling system due to increased fan and water pump speed the result being  the motor will cool down to the point where the ambient underhood temp is lower, and the valve closes and the vacuum leak will stop, returning the engine to a normal idle speed.   This cycle repeats itself over and over. Obviously this will only help during periods of engine idle . Remember, this was engineered in the early sixties and in theory is workable.  What normally happened is that IF the little rubber needle valve did lift from the brass seat and cause the idle to increase, it sometimes would not seat properly when  cooler, and caused an eratic idle.  Most were tossed in the garbage back in the day.  In the real word this little device probably caused more problems than it solved!  It had a somewhat short life, was kind of a band-aid fix, and was replaced with a bigger and better cooling system as more and more Fords products were sold with factory AC.  I do not remember the idle speed increasing in proportion to the temp.
John Murphy
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: October 08, 2010, 06:20:25 AM »
Thanks for the explanation.
66 Metuch Conv
Offline autonomousbronco
« Reply #5 on: May 10, 2011, 06:24:11 PM »
"When loading the trailer: Keep shiny side up and rubber side down."
Offline MattDoscher
« Reply #6 on: May 10, 2011, 11:47:39 PM »
Good explanation Murf.  Does anyone know if this was installed on '65 C codes w/ a/c?  Or was it just a '66 thing?  Just wondering.
Matt
Matt Doscher
5H25T582252
Offline bryancobb
  • 2009 Ridn' Around
« Reply #7 on: May 11, 2011, 08:16:40 AM »
I'm almost positive that Mannel's book shows it on '65 and '66 CCodes.
66 Metuch Conv
Offline Chris
« Reply #8 on: May 12, 2011, 04:57:08 PM »
It's also used on 64 1/2 cars. My June 64 convertible is an open emissions car meaning there is no PCV valve but instead it has the road draft tube off the intake manifold (oil fill is on the timing chain cover too, so unique valve cover configuration in that neither have holes). So my hot idle compensator comes off the carb spacer and is attached to a short piece of hose with two Corbin clamps, as shown in Mannel's book in the Ford diagram (example with incorrect clamps below).
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #9 on: May 12, 2011, 06:08:37 PM »
+1 to the above but mine looked like this ( also a june 64.5)
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline 66RavenGTCoupeAgain
Re: Hot Idler Compensator
« Reply #10 on: June 08, 2016, 10:20:48 PM »
This may help this thread.....
I am chasing part numbers for all the other bits shown here? Can anyone help?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: Re: Hot Idler Compensator
« Reply #11 on: June 08, 2016, 11:13:25 PM »
Believe your "PCV adapter with male thread" is just the end of the C5ZZ-6A666 PCV
The compensator block's number is 379573-S a hardware number
Elbow is another hardware number of 37854-S
Clamps are all 18572
Illustration is of a 65 system rather than a 66
« Last Edit: June 09, 2016, 05:16:41 PM by J_Speegle »
« Reply #12 on: June 09, 2016, 12:34:55 AM »
The 66 Engine Accessories shows a slightly different setup, no threaded PCV valve, but the clamps are 97331-S35 and are available from AMK.
That part is listed as a "T" but used as a housing.
Believe the part number should be 378754-S (ref Ford Standard Utility Parts, Jan 65, pg 39, type 6)
« Reply #13 on: June 09, 2016, 02:02:01 AM »
The 66 Engine Accessories shows a slightly different setup, no threaded PCV valve, ...............Believe the part number should be 378754-S (ref Ford Standard Utility Parts, Jan 65, pg 39, type 6)
Yes that (no threads) would be one of the differences between the pictures posted and a 66 system if that is what one is doing - besides the lack of the threaded adapter
Thanks on the number Though it may not matter. Just dropped a number transposing from the picture to the post :(
