Author Topic: Early Timing cover?  (Read 821 times)
Offline DKutz
Early Timing cover?
« on: July 31, 2018, 07:19:29 PM »
Pulled the timing cover off a march 30, 64 289.  It has the screw on timing pointer, not the cast in pointer.  Does anyone remake these?  Not sure if this one will clean up well enough to reuse.
Re: Early Timing cover?
« Reply #1 on: July 31, 2018, 07:44:44 PM »
Don't be afraid to use the casting number to identify what cover you have. It "may" be not what you need.
Offline DKutz
« Reply #2 on: July 31, 2018, 09:05:18 PM »
If I had it handy I would. Car is not at my house
Offline DKutz
« Reply #3 on: July 31, 2018, 10:43:00 PM »
Ok, from what I can read.
C30E-6059B
Offline ChrisV289
« Reply #4 on: July 31, 2018, 11:24:04 PM »
I believe the later years (68+) had the screw in pointer. The early cars had the cast in one. NPD sells a repro with the aluminum water pump which you should have.
2009 V6 Mustang Coupe
« Reply #5 on: August 01, 2018, 12:25:19 AM »
C30E-6059B
It sounds like the service replacement timing cover what with the screw on pointer and designed for aluminum waterpump. It is a replacement so if damaged you will not be losing much in the way of authenticity if you replace it with a repro.
