Author Topic: 1966 fastback luggage shelf behind seats  (Read 906 times)
Offline edwardgt350
« on: July 29, 2018, 03:10:03 AM »
can anybody provide pix and details of package/luggage section behind the rear seat? see picture below.
specifically, the chrome oblong escutcheon. do the screws have washers?
also what type screw/washer is about 5” forward of the escutcheon plate?
the assembly manual is light on details.
amk sent 4 machine screws and two black sheetmetal screws. where do the black screws go?
« Last Edit: July 29, 2018, 03:45:15 AM by edwardgt350 »
Re: 1966 fastback luggage shelf behind seats
« Reply #1 on: July 29, 2018, 08:34:13 AM »
Here's a start.  If you can ask questions referencing part numbers that should help us all from getting off track
Offline edwardgt350
« Reply #2 on: July 29, 2018, 11:10:13 AM »
screws E and K in view DD
also see picture of red interior car. there is a screw about 5” forward of the round plate.
Offline edwardgt350
« Reply #3 on: July 29, 2018, 12:48:39 PM »
67gta289, i think your diagram is for a 1965. 1966 has the escutcheon cups(plates).
« Reply #4 on: July 29, 2018, 01:07:27 PM »
There are 6 screws that are visible on the last panel, the fixed one, on a 66 Fastback. Four hold the panel to the body, the two rear most, 54511-S13, hold the bumper cup (called catch) and the panel, the front of the bumper cup is held by short screws, 54505-S13.
- the chrome oblong escutcheon. do the screws have washers?
The front of the panel has a cup washer, 34970-S, used with the screws, 52979-S13.
I believe those may be the screws, 52720-S2, holding the retainer bracket on the underside of the rear panel.
You should spend a few minutes in this Forum's Library under top Mustang Hardware Spreadsheets 64-66. You will fing two spreadsheets, one by application, the other by part number. Both have descriptions of hardware used, with referenced sources.
Your drawing is from the service manual and, as such in many instances, uses replacement parts and hardware, not factory original that are shown in the assembly manuals. Yes, there are differences in plants, date of assembly and parts availability, many of which are documented on this forum.
Offline edwardgt350
« Reply #5 on: July 29, 2018, 01:41:22 PM »
thanks. car is a san jose gt350 march/april build date.
just to summarize....
cup/catch has four machine screws, no washers.
the screw five inches forward is a self tapping screw with a washer.
appreciate any feedback.
« Reply #6 on: July 29, 2018, 01:43:22 PM »
Correct, it was merely a starting point to start referencing part numbers, and as Jim mentioned the assembly manual diagram is better.  I don't have the 65/66 version so could not include it.
« Reply #7 on: July 29, 2018, 07:19:40 PM »
...san jose gt350 march/april build date. ...
..cup/catch has four machine screws, no washers.
+1 For your car, plant and assembly period
