Author Topic: 72 Dearborn Seam sealer  (Read 1472 times)
Offline nham3407
« on: October 06, 2010, 01:39:30 PM »
Looking for help on the correct seam sealer and where it can be purchased.  Need to seal floors, trunk floor, and quarter structure on a 12/27/71 production date Mach 1.  Attached photo shows what it looks like.  Never mind the holes in the floor.
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
Offline c9zx
Re: 72 Dearborn Seam sealer
« Reply #1 on: October 06, 2010, 05:42:01 PM »
 It seems to be sprayed on under coating to me. I used liquid under coating and an under coating spray gun. I've had the stuff for 20 years, don't recall where I got it. Maybe Eastwood.
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
« Reply #2 on: October 07, 2010, 12:53:14 AM »
The original appears to just like sound deadener sprayed on heavy as it appears to be a tar and asbestos base that seeps through the exterior paint applied over it
With that said and since it will not be visible (in this location) you can choose to reproduce the original stuff by using like a spray undercoating  or improve by applying it with a brush (to cut down on the mess or use a modern product such as an acoustical spray
