Author Topic: original '66 289 fuel pump height  (Read 867 times)
Offline socalgt
« on: July 10, 2018, 06:51:52 PM »
I removed the pump from my '66.  Although it isn't original, all the aftermarket ones I  find are taller. than the one I took off..the two tubular extensions the lines attach to are about an 1" longer than the ones on the pump I removed. so I'd like to know the height of the original pump, or to be more specific of the tubes themselves.  I don't want to have difficulty attaching the original style steel line (pump to carb)
Thanks.....
Re: original '66 289 fuel pump height
« Reply #1 on: July 10, 2018, 07:00:55 PM »
Where would you like the reference points to be measured from since the shape of aftermarkets can be very different?
Guess it could be made from the approx center of one fo the mounting bolt holes but it will only be close at best without building a fixture or something like that
Offline socalgt
« Reply #2 on: July 10, 2018, 08:13:26 PM »
A measurement from one of the mounting holes would be great.  I'll measure mine from that same point.
« Reply #3 on: July 10, 2018, 08:47:23 PM »
From a NOS one I had out on the work bench I measure from the bottom of one of the bolt holes and got about 5"  or 5 1/8" to about center of the bolt hole. Not real accurate but eye balling it
Offline socalgt
« Reply #4 on: July 10, 2018, 10:36:55 PM »
removed pump vs. new reproduction
Old pump tubes extend about 2" and the new pump 2 1/2"
« Reply #5 on: July 10, 2018, 10:42:37 PM »
Neither are originals ;)
« Last Edit: July 10, 2018, 10:45:11 PM by J_Speegle »
« Reply #6 on: July 11, 2018, 12:04:03 AM »
Here is a  picture of a 289 fuelpump to be used as a example of the original style and design that is like what came on your car from the factory.
« Last Edit: July 11, 2018, 12:09:31 AM by Bob Gaines »
Offline socalgt
« Reply #7 on: July 11, 2018, 12:47:21 AM »
I knew neither was original, but I wanted to replace it with one with the correct dimensions so the steel line to the carb would connect properly.  Between the two, it appears the "current replacement" is definitely too tall.
« Reply #8 on: July 11, 2018, 01:39:42 AM »
I agree.
