Author Topic: color of seat tracks for 69-70 Mustang  (Read 733 times)
Offline Bossman963
« on: July 10, 2018, 01:57:58 AM »
Are the seat racks/tracks for the high back Mach1 completely painted black? and what color
are the seat bolts and s[prings natural or black?
thx in advance  Mike
« Last Edit: July 10, 2018, 09:33:28 AM by carlite65 »
2-69 B302 -twins, 1-1970 Cougar Eliminator B302- matching numbers, 70 B302 in progress, 68 Charger, 74 Pantera GTS, 2 fox body Mustangs 1 conv
Re: color of seat racks for 69-70 Mustang
« Reply #1 on: July 10, 2018, 03:08:13 AM »
First picture I ran across. Should provide you with the finish for the tracks (black), stud plates, nuts (red safety dye)  and maybe attaching bolts (big Phillips heads). From a mid year 69.
The spring that attached from the track is painted glossy black. Or at least a glossier semi-gloss
« Last Edit: July 10, 2018, 03:17:35 AM by J_Speegle »
Offline Bossman963
Re: color of seat tracks for 69-70 Mustang
« Reply #2 on: July 10, 2018, 11:34:23 AM »
Jeff thanks for the quick response
« Reply #3 on: July 10, 2018, 05:52:58 PM »
I will add so as to confirm that the stud plate is a P/O and not bare steel . It can be somewhat light in nature. Just in case you couldn't tell from the picture. I typically strip and P/O the entire rail assembly then go back in a tape off before painting . Just the way I do it.
