Author Topic: 66 San Jose rear bumper guard hardware and installation?  (Read 1230 times)
Offline edwardgt350
« on: July 05, 2018, 11:54:53 PM »
hello
does anyone have clear pix or instructions for the installation of the rear bumper guards?
the diagrams in the assembly manual are not that clear.
thanks
« Last Edit: July 06, 2018, 04:08:00 PM by J_Speegle »
Re: rear bumper guard hardware and installation ?
« Reply #1 on: July 06, 2018, 12:20:02 AM »
I doubt a picture will help as much as the assembly manual, I'm looking at the page right now. Items 4 are the right and left brackets, items 5 are the two bumper guards. The item numbers are also the assembly steps, and include attaching hardware required. Mixed in is any sealant required, I like 3M8578 strip caulk, to act as a sound deadener.
Offline edwardgt350
« Reply #2 on: July 06, 2018, 10:10:40 AM »
are all four bolts black oxide or the gold cad bolts also used?
« Reply #3 on: July 06, 2018, 12:32:16 PM »
In this Forum's Library section, you will find several topics that might help: Mustang Hardware Spreadsheet 64-66,  sorted by application and by part number; FINISH CODES, Short List. Browse away.
Offline ChrisV289
« Reply #4 on: July 06, 2018, 12:58:50 PM »
The zinc dichromate bolts will be the top bolts in the trunk....When and where was the car built?
2009 V6 Mustang Coupe
Offline edwardgt350
« Reply #5 on: July 06, 2018, 01:43:23 PM »
san jose april 1 build date
Offline ChrisV289
« Reply #6 on: July 06, 2018, 01:59:36 PM »
Jim's spreadsheet should confirm but I think you need the bolts with the star washer like the fender bolts used on the bottom of the bumper guards.  Are those your original ones?  Can you see any teeth marks?
Offline edwardgt350
« Reply #7 on: July 06, 2018, 02:20:43 PM »
no not the orig guards.
Re: 66 San Jose rear bumper guard hardware and installation?
« Reply #8 on: July 06, 2018, 03:36:11 PM »
Picture of the upper mounting bolt and sealer in this thread. Reply #1 under T3
http://www.concoursmustang.com/forum/index.php?PHPSESSID=mdomkmbdc7tlrrn3kruit1skh5&topic=12291.msg74730#msg74730
Lower bolt from the back side of the valance is more difficult to find a picture of - access and angles. Will look
« Last Edit: July 06, 2018, 04:07:52 PM by J_Speegle »
« Reply #9 on: July 06, 2018, 04:07:43 PM »
Not real clear shots but it appears the lower mounting bolt used a flat (wave/bump) washer.
Couple more supporting pictures of the attaching bracket and hardware
NOTE: Updated the title to reflect the year and plant of the OP's request
