Author Topic: Seat belts tight or loose  (Read 514 times)
Offline rocnhrse
« on: July 02, 2018, 02:22:47 PM »
Just  got my deluxe  seat belt's back from ssnake oyl, little long in getting  them but excellent  job, when installing  the belts  as per instructions  in Osborn manual, with the bolts and washers tight  the belt will  move up or down as if to line  up for different  size people,  is this correct? the shoulder  bolts  bottom out,  and leaves  the movement , using  original  replated bolts, which  where all the same length
67 mustang  GTA  S code fastback  San Jose  April 67
Re: Seat belts tight or loose
« Reply #1 on: July 02, 2018, 03:14:39 PM »
Yes the outer belts should not be attached so they do not swivel when the attaching hardware is tightened
Offline rocnhrse
« Reply #2 on: July 02, 2018, 03:43:49 PM »
Thanks Jeff
1967 eight barrel
  • Guest
« Reply #3 on: July 07, 2018, 12:12:12 AM »
Ssnake oil? Poor guy. Python restoration is two weeks and less than half the price, not to mention better work.
