Author Topic: 69 NJ - Proper placement tags and sticker  (Read 1794 times)
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« on: June 26, 2018, 04:06:17 PM »
Hi  i need some help wont it to be done the correct way  i have a 69 mach 1 body 63C, NJ built on April 1,  h code 351 2v,  3 speed color M5  ,trim 3A  what tag and sticker would have been place on this car and what way would have they been place    Thank you
« Last Edit: June 26, 2018, 05:20:59 PM by J_Speegle »
Re: 69 NJ - Proper placement tags and sticker
« Reply #1 on: June 26, 2018, 06:16:46 PM »
Hope these help
Battery Inspection Location
Service Spec Location
Air Cleaner - Cubic Inch & Filter Replacement/service Locations
Engine ID Sticker & Timing/Emissions Decal Location
Tire Pressure Sticker Location
Tie Down Instructions
Jacking and Emission Standard Locations
Jack Location
Offline DEWilson
« Reply #2 on: June 27, 2018, 12:23:10 AM »
thank you Jeff     wow that is the first service spec label seen place there   all way see them in a pic on the tower where they place difference for different motor or plants
« Reply #3 on: June 27, 2018, 05:08:56 AM »
thank you Jeff     wow that is the first service spec label seen place there   ................where they place difference for different motor or plants
Yes differ between plants and even at NJ apparently based on time period. Have seem some (other plants and times) where having AC may have resulted in different locations.  But for your plant and time period found a bunch where they are shown on the three examples above
« Reply #4 on: June 27, 2018, 09:36:56 AM »
I have recently seen 3 unmolested 69 NJ cars with the service spec decal on lh front center cowl panel area just like jeffs photo & 1  decal was upside down from factory.
Offline DEWilson
« Reply #5 on: June 27, 2018, 07:40:50 PM »
   thank you
Offline DEWilson
« Reply #6 on: June 28, 2018, 12:37:50 AM »
  so on the battery sticker is there  anyone that does them up all filled out with stamping
plus would this tag be used that i see on npd that list for 69 ,antifreeze tag,the final acceptance tag, battery tag, voltage reg warning tag,  e-2 window tag
« Reply #7 on: June 28, 2018, 07:24:56 AM »
ecs makes stamped battery decals  & many tags & decals have been made but u only need the correct ones on your specific car so do your reseach first.
« Reply #8 on: June 28, 2018, 01:47:01 PM »
For instance the E2 window tag would have been taken off at the dealer during dealer prep. That is unless you are going to show the car the way it came off the transport with bags over the seats, steering wheel. antenna hole not drilled in fender or installed etc. As Ed said do your research and decide which way is best for your car.
« Reply #9 on: June 28, 2018, 04:48:53 PM »
ECS is the only one selling commercially the filled out battery inspection decals but they are filled out as they would have been for 69-up Dearborn cars. Other years and plants were filled out differently and some years used a different sticker that what is offered pulse they sell a vinyl sticker rather than a paper based sticker like originally done. PM sent
Just my observations studying these details for 30 plus years
Don't believe the E2 came from a 69 NJ car. If I recall correctly that sticker was originally found on Dearborn cars.
As has been mentioned figure out how the car will be presented. Will it be as delivered to the dealership or to the first buyer and don't mix components from each period. It just looks confusing IMHO and shows that you didn't do all your homework ;)
Offline DEWilson
« Reply #10 on: June 28, 2018, 11:25:59 PM »
so yes i wont to do as the first buyer how it would have been when picked up   i see so many car with every sticker  that made on them and yes it looks bad and wrong i do know that there was thing done differently  from plant to plant and month to month   being in Maine a lot of thing where gone from winter weather and former owner repainting  and it being my first car as a teen in 78.. glad to say i still have it and now it is good as day one from the dealer
Offline DEWilson
« Reply #11 on: July 07, 2018, 12:52:41 AM »
 ok had someone ask me why did not have a caution sticker on the fan shroud that it was a factory item i told i think they was wrong..   i was thinking that did not have one from the factory..  am i correct or should i have one  was thinking where it was not talk about that it was not used
« Reply #12 on: July 07, 2018, 01:28:52 AM »
Its been covered here and elsewhere since the internet opened for us common folk but no reason not to go over it again. Originally a 69 NJ car would not have received one not any other 69 Mustang other than the Boss 9 on the little figure guard so I guess if worded correctly you could say any Mustang on the shroud
The CAUTION fan decals started showing up as I understand it in 72 as a result of a accident or a concern for one and Ford sent out hundreds of thousands of stickers to dealer with the instruction to place one on every car that came in, every used car and every car that went through servicing and repair.  They also added one to every service replacement fan shroud so you can understand why we so often see them on unrestored or low mileage cars today and why you find so many (well they are starting to dry up) NOS ones on Ebay
9TO2Hknot4cell
  • Guest
« Reply #13 on: July 08, 2018, 10:56:37 AM »
My 69 Mach 351W, NJ car Feb24 is placed there on the apron as well.
Offline DEWilson
« Reply #14 on: July 15, 2018, 07:41:28 PM »
Thank you  everyone for the info
