Author Topic: brake master cylinder advice/help please  (Read 790 times)
Offline edwardgt350
« on: June 25, 2018, 01:18:14 AM »
bought a new brake master cylinder for a 66 gt350. new one doesnt come with a push rod and we cant remove the old push rod from the housing. we tried placing it in a vice and using a slide hammer but no luck removing it.
any suggestions?
Offline must69
Re: brake master cylinder advice/help please
« Reply #1 on: June 25, 2018, 04:40:51 AM »
Did you try soaking it in some sort of lubricant or "nut cracker"?  May just need to soak awhile.
Offline NEFaurora
« Reply #2 on: June 25, 2018, 10:11:07 AM »
Hang the rod from a bar on the vise and just bang it off... It will go...You have to break the internal clip to get it off..
:o)
Tony K.
MCA#70001
Offline Hipo giddyup
« Reply #3 on: June 25, 2018, 01:50:03 PM »
I had the same problem a little while ago. Since the internal piston should be replaced, I used a cut-off wheel to cut it almost in half. Then I used a screwdriver and twisted between the two halves to split them apart. In my case the clip was retained on the push rod and I could use it again in the new piston.
« Reply #4 on: June 25, 2018, 01:52:10 PM »
What HE said! You'll want to re-use the clip.
Offline 67350#1242
« Reply #5 on: June 25, 2018, 03:22:52 PM »
I came across a clip for 65-73 manual brake push rod:
http://www.american-mustang.com/index.php?main_page=product_info&products_id=6901
If you break yours looks like they're available.  Maybe you can study the picture and figure a way to unlock it with a fabbed up tool?
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
