Author Topic: What would keep the fuel sending unit from working?  (Read 1069 times)
Offline Matt1968
« on: June 19, 2018, 04:54:29 PM »
It works fine outside of the tank (lead hooked up, a ground wire attached from sender to tank opening). Gauge works the full range.
Installed with 5 gallons of gas poured in (16 gal tank) it reads fully empty. Float is currently in a pot of water, not sinking.
What's going one?
Re: What would keep the fuel sending unit from working?
« Reply #1 on: June 19, 2018, 06:46:02 PM »
Bad ground sending unit to tank and/or tank to body and/or body to battery
« Reply #2 on: June 19, 2018, 08:51:50 PM »
Another possibility is a broken wire for the fuel sending unit (yellow/white).  Yet another possibility is that the gauge itself is mis-positioned on the dash cluster, causing it to be grounded.  When that happens, other gauges (water temperature, oil pressure) are also off.
