Author Topic: 66 Hertz Shackles  (Read 1404 times)
Offline ChrisV289
66 Hertz Shackles
« on: June 18, 2018, 02:46:32 PM »
Can anyone confirm that 66 Hertz cars came with the offset shackle on the LH side?  Both NPD and VA Mustang sell this and it is ½ inch rod and the matching one for the RH side.  The standard 65-72 is 9/16 inch rod.  Just want to confirm before I place an order…
2009 V6 Mustang Coupe
Re: 66 Hertz Shackles
« Reply #1 on: June 18, 2018, 03:36:40 PM »
66 Hertz used the same rear shackle brackets as 66 Mustangs equipped from the plant with dual exhaust.
Offline ChrisV289
« Reply #2 on: June 18, 2018, 03:56:19 PM »
Thanks Jeff.  Also just confirmed that the LH side on my dad's is offset.  He is starting the process of restoring the rear end as he has a pinion seal leak.  Will be posting pics of his progress in the members section.
« Reply #3 on: June 18, 2018, 04:18:51 PM »
The size for 66 thru 73 shackle bushings is 1/2 inch. Earlier Mustangs used a 9/16 inch dia bushing.
