Author Topic: Serial Number Plate  (Read 1191 times)
Offline 1970 Snake
Serial Number Plate
« on: June 10, 2018, 03:21:05 PM »
I am in the process of installing my S/N plate back on the body under the windshield and would like to refinish the metal base, but am not sure what I should use for refinishing the metal the S/N is stamped into. It does not appear to be painted but is more of a bluing/black type anodized type finish. Any help would be appreciated.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Serial Number Plate
« Reply #1 on: June 10, 2018, 07:57:13 PM »
If you are referring to the black box with the curly ques around the perimeter it is acid etched onto the metal plate before the plate is stamped. ECS makes the best alternative decal to the original if yours has been damaged.
« Reply #2 on: June 10, 2018, 11:02:08 PM »
If you go this route I suggest that you cut the center section, where the stamped VIN and characters are, out of the clear decal.  The film will not conform to the stampings, may buckle or lift in that area.
Just a suggestion ;)
Offline 1970 Snake
« Reply #3 on: June 11, 2018, 12:18:35 AM »
Sorry I probably wasn't clear enough, its not what you are describing it for the VIN and have attached a picture.
Its the piece that is pop riveted to the body under the windshield.
« Last Edit: June 11, 2018, 12:24:01 AM by 1970 Snake »
Offline Mike_B_SVT
« Reply #4 on: June 11, 2018, 02:17:29 AM »
They are thinking '69 models ;-)
I always thought they were just painted, but maybe it is more of a black annodized coating?
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
