Author Topic: Power Brake booster  (Read 654 times)
Offline orgnl70
Power Brake booster
« on: June 05, 2018, 05:54:25 PM »
67 S code. Metuchen built. 11/17/66 build date.
What would be the correct finish for a Midland Ross brake  booster.(FORD logo inscribed)
I have seen from gloss black to flat black.
1967 eight barrel
  • Guest
Re: Power Brake booster
« Reply #1 on: June 05, 2018, 06:13:26 PM »
Semi-gloss black. Ford logo is a service replacement.
« Reply #2 on: June 05, 2018, 08:08:53 PM »
+1 . You can make the Ford logo disappear with a little body work. That is if you care to make it look like assemblyline . I can only assume you are concerned given the level of sheen question.
Offline 196667Bob
« Reply #3 on: June 06, 2018, 11:25:56 AM »
Ditto on both Replies. And don't forget, the Master Cylinder should be attached to the Booster before painting as both should be painted together.
Bob
MCA 04909
