Author Topic: Hurst t5 shifter  (Read 5158 times)
Offline 91saleen26
Hurst t5 shifter
« on: June 05, 2018, 12:43:19 PM »
Has anyone ever had any luck with rebuild parts for these. Thank you in advanced.
Offline KevinK
Re: Hurst t5 shifter
« Reply #1 on: June 06, 2018, 12:06:54 PM »
I have not played with one of these. Typically, the issue is worn out bushings where the handle attaches. There are metal replacements available. Again this is standard Ford stuff and I did have an issue with my 84 GT Turbo. I think the SVO is similar or the same.
I can look into it when I get back in country. Currently in Africa
MCA #33800, Gold Card 3rd Gen
BAMA Member
Offline svo2scj
  • Moderator
« Reply #2 on: June 12, 2018, 08:43:52 AM »
Hi
As Kevin said , usually it is the "shifter to housing" bushings that are the issue to give a VAGUE feeling!
Mark
P.S.  Unless you have a 84/85 SVO hurst gate , that is WAY different than the 85/5/86.  Personally I wouldn't want the 84 style.
