Author Topic: Looking for peoples process on Leaf Spring prepping for Gun Blueing.  (Read 5237 times)
Offline Morsel
Re: Looking for peoples process on Leaf Spring prepping for Gun Blueing.
« Reply #15 on: May 26, 2018, 01:06:31 PM »
One hint - do not handle any item after you've blasted it. Wear rubber gloves, or use shop towels. Be paranoid about keeping the item clean.
Haha, learned that one the hard way a while back, now I always wear rubber gloves when handling every piece I blast through the final coating process...
Jason
Offline OldMustangGuy
« Reply #16 on: May 26, 2018, 02:12:37 PM »
I recently blasted a new set of springs from Eaton to remove the paint in preparation for blueing. I too have a blast cabinet that is too narrow to fit a spring section into. So, I opened up the end door and, with a lot of duct tape and heavy plastic, I built a "balloon" on the end of the cabinet to allow the spring to fit in. It worked pretty well except that a lot of the media would collect in the "balloon" so I would have to occasionally shake it back into the cabinet.
If your doing a new set of springs, the paint that Eaton uses is tougher than nails so I found that applying some heavy duty paint stripper prior to blasting helped a lot.
For soaking large parts like spring sections or drive shafts in Evaporust, a trough can be easily built using plastic rain gutter parts. Another, albeit pricey technique, is to use a large plastic garbage can as a dipping tank...obviously takes a significant amount of Evaporust to fill it but it will last a long time and you can do a lot of parts all at once.
« Reply #17 on: May 26, 2018, 03:30:54 PM »
I have made some odd shaped soaking tanks out of plastic sheets and using plywood sides and bottom cut to make shapes that require the least amount of fluid material.
« Reply #18 on: May 26, 2018, 03:49:51 PM »
This is why I buy Rust911. Same thing essentially as your EvpoRust only it is affordable.
$60 goes a REALLY long way! Hind sight being 20/20, I would have just bought 4-5 gallons (makes 64-80 gallons) up front, built a few boxes like Bob mentioned and just dipped everything WHOLE instead of in sections like I ended up doing. $300 is REALLY CHEAP when you see the result and consider how much extra time I spend screwing around trying to "be cheap and affordable".
« Last Edit: May 26, 2018, 03:53:13 PM by 67gtasanjose »
« Reply #19 on: May 26, 2018, 04:21:14 PM »
Quote
I buy Evaporust in 5 gallon buckets on Amazon. If you are a Prime member shipping is free! I wouldn't say it's cheap but is much more affordable that way than buying it by the gallon at Walmart, etc...It's about $80 for 5 gallons on Amazon.
« Reply #20 on: May 26, 2018, 04:42:38 PM »
AMAZON is a great tool for savings! I like to use them too, however...
5 gallon bucket of Evapo-Rust = 5 gallons of Dip (COST around $1280 for 80 gallons or $899 for 55 gallon barrel)
5 gallons of Rust911 CONCENTRATE = 80 gallons of Dip (COST around $300 for same 80 gallons, also with FREE shipping)
I like the math! I also LOVE the results, I have tried Evapo-Rust and believe it to be phenomenal! I have ALSO used Rust911 ever since I tried it and will NEVER go back when I see the savings. To date, I have had no ill-effects of using this product.
Don't forget to buy a gallon their MetalShield 2009 to guard against Flash Rust, an affordable alternative to Boeshield T9
https://www.amazon.com/Rust911-16-gallons-Economical-Safe-Use/dp/B0031HQJWW?SubscriptionId=AKIAJ2F6RDUSIYCWQMFQ&tag=sa-sym-new-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B0031HQJWW
https://www.rust911.com/
« Last Edit: May 26, 2018, 04:44:44 PM by 67gtasanjose »
Offline Morsel
« Reply #21 on: May 27, 2018, 02:50:04 PM »
I actually came up with a super cheap and easy way to soak my springs in Evaprorust that doesn't use that much product. I bought one of those black 4 inch flex tubings from the hardware store for about $10. It's just a little wider then the spring and about 10 feet long. Because it's flexible it bends to the shape of the spring. I then just bent the end up close to the long spring ends, poured in about 2 1/2 containers of Evaporust which filled the tube and now is soaking my long spring. I have to do the long ones one at a time, but the short ones all fit together. Anyway, thought this might help people in the future save a touch of money... also easy to pour back into the containers when your done.
On a side note, yes, I had to strip the paint off first with stripper, I'm going to soak each one, then blast them and onward ;)
Jason
« Reply #22 on: May 27, 2018, 04:10:40 PM »
Jason
Good alternative container . I like the easy to pour out aspect compared to the way I did it. I wanted to ask why the extra steps? Strip paint ,soak in Evaporust, then blasting. Why wouldn't you go from painter stripper straight to blasting?
« Reply #23 on: May 27, 2018, 04:55:59 PM »
I like it. You're using the contents of the hat rack for the good of all mankind.
Offline Morsel
« Reply #24 on: May 28, 2018, 11:49:58 AM »
Plus I can attach it to my down spout from my rain gutters afterward and direct water away from the garage ;)
My springs were a disaster, they were super rusty under some epoxy paint, I tried first just blasting, no good, then even after using stripper, there was still paint left, I soaked in Evaporust after that and strangely because of the rust they painted over, a lot more came off. They look pretty good, but the main reason I'm blasting afterwards is to even out the over all finish and surface before I gun blue, I want as even a surface tone as I can get prior, it's a large area and going to be battling a smooth even finish already...
One thing that was fun, I found some paint marks while I was stripping them, for future reference, 1966 February 10th San Jose factory GT K-Code, driver side springs had green and yellow spray dots, passenger side had green and yellow stripes, mixed, have you seen this before?
Jason
Jason
« Reply #25 on: May 28, 2018, 12:28:54 PM »
Rain? In "parched" California? Only in the movies.  8)
« Reply #26 on: May 28, 2018, 01:28:02 PM »
Jason
Jason
I have seen mixed before just a seldom occurrence in the big picture . It is typically a earlier 66 date around the transition time.
« Reply #27 on: May 28, 2018, 05:15:26 PM »
Have seen this many times but then I see allot more San Jose examples than most  ::)
Offline Morsel
« Reply #28 on: June 04, 2018, 06:09:03 PM »
OK, one last question here, about to get these ready to assemble my leaf springs, does anyone use any grease or wax between each spring to promote a good "slide" and avoid any spring noise between each leaf or do you just go raw metal to metal ;) Obviously these will be Boeshield'ed prior to assembly.
Jason
« Reply #29 on: June 04, 2018, 06:25:50 PM »
Jason
I have seen it done ether way but personally would apply some grease.
