Author Topic: Intake manifold's backing (baffle) plate  (Read 1782 times)
Offline AU Finger
Re: Intake manifold's backing (baffle) plate
« Reply #15 on: May 24, 2018, 05:25:41 PM »
Cast iron is relatively soft material.  These spline drive rivets are easily driven in with a medium sized ball peen hammer.
May 25, 1964 D code convertible
« Reply #16 on: May 24, 2018, 07:40:44 PM »
+1 . If you don't care if you dent up the round surface of the rivet it doesn't matter much . The cover on the underside of the manifold is one of those places where it doesn't matter IMO.  I use the proper anvil tool because I am typically installing them on the valve cover sparkplug clip (Cobra fined covers) which is highly visible and I don't want to mar the head of the rivet.
Offline MustangAndFairlane1867
« Reply #17 on: May 25, 2018, 12:51:40 AM »
Bob:  Where can I buy 4 of the spline drive "rivets" and the correct anvil tool?  Thanks, Ron...
« Reply #18 on: May 25, 2018, 01:04:07 AM »
AMK on the rivets and I made my tool but I am sure tool company's make them. FYI you would really only need the tool on high visibility rivets IMO.
« Reply #19 on: May 25, 2018, 01:36:09 AM »
Well, got the baffle off the underside of my intake today.  I used the large chisel and baby sledge hammer recommended here and it went well for the first two spiral rivets, but took the heads off the other two which were "frozen" in place.  Shouldn't be a problem since I plan to drill and tap the holes for threaded allen button heads anyway.  As I look at it now the trickiest part of the task will be locating the exact center of the two broken rivet studs (they broke off flush with the bottom of the intake) so I can accurately drill out the holes.  Below are some pictures of the project I took this afternoon.  Ron
« Last Edit: May 25, 2018, 01:43:20 PM by MustangAndFairlane1867 »
Offline Hipo giddyup
« Reply #20 on: May 25, 2018, 10:25:41 AM »
Nice job!!  ;)
