Author Topic: 69 250 E Transmission Crossmember Discussion  (Read 1017 times)
Offline C9ZZ-16228-B
« on: May 18, 2018, 11:47:43 AM »
Thanks Ruger!  Very interesting, it is a different piece!  Out of curiosity, does your E have a C4 transmission similar to a full size Ford, with a 164 tooth flexplate and bell housing and a pan-fill dipstick tube?
Garrett
Offline ruger
Re: 69 250 E Transmission Crossmember Discussion
« Reply #1 on: May 18, 2018, 11:50:39 AM »
Yes,  C4. As far as I know on the flex plate.  Haven't looked in a few years.
1969 Sportsroof Mustang E'
63D
250 six cyl.
C4 trans.
Dearborn build Nov. 1968
« Reply #2 on: May 18, 2018, 11:53:19 AM »
Do you recall if the trans dipstick tube goes into the aluminum case or into the trans pan?
Offline ruger
« Reply #3 on: May 18, 2018, 11:54:26 AM »
I'm doing this on my phone,  something new to me.  Will re post the pics.
63D
250 six cyl.
C4 trans.
Offline ruger
« Reply #4 on: May 18, 2018, 11:55:39 AM »
Will have to look later.  At work at the moment.  Is this cross member different compared to others you have seen?
63D
250 six cyl.
C4 trans.
« Reply #5 on: May 18, 2018, 12:16:23 PM »
Yes, it has its own part number specific to the 250 E, and I wasn't sure what the differences are.  I can see right off the bat that the slotted holes for the trans mount are much shorter than other 250 crossmembers, i'll have to dig one out and do a proper comparison.  Apparently, there were quite a few differences between a regular 250 and a 250E, drivetrain-wise.  Weird and wild stuff!
thanks,
g
Offline ruger
« Reply #6 on: May 18, 2018, 12:19:39 PM »
Yes,  I talked to Ralph Arning at Ford.  He was around back in the 60's and remembered all of the engineering going into the E's.  He did not directly work on it but remembered they went wild on engineering.   Told me also the engineers were all passed away now.  I am still learning about the E' after several years of research.
63D
250 six cyl.
C4 trans.
« Reply #7 on: May 18, 2018, 12:29:36 PM »
I have a 68-71 Master Parts catalog that calls out a lot of the E-specific parts.  For example, it had its own service block, and calls for a different transmission mount than any other Mustang.
Offline ruger
« Reply #8 on: May 18, 2018, 12:37:34 PM »
Cool,   I cannot remember if it is in good usable condition.  Could you give me the # to that mount?
« Last Edit: May 18, 2018, 12:42:16 PM by ruger »
63D
250 six cyl.
C4 trans.
« Reply #9 on: May 20, 2018, 11:36:17 AM »
They used a C8OZ-6068-A
Offline ruger
« Reply #10 on: May 20, 2018, 07:06:31 PM »
Thank You very much.  I hope I don't have to chase more parts around.   I am looking for a better seven blade fan with clutch.  Would you happen to have that #.  Sorry,  I promise not to ask too much.
63D
250 six cyl.
C4 trans.
« Reply #11 on: May 22, 2018, 05:25:34 PM »
Split the subject and moved it since this line of discussion took a right turn off thread  ;)
Are you asking for your 69  six cylinder C4?
I Found C8OZ-6068-A listed for convertible applications rather than the C8ZZ-6068-A service replacement for sportroofs
« Last Edit: May 22, 2018, 05:45:06 PM by J_Speegle »
Offline ruger
« Reply #12 on: May 23, 2018, 07:53:25 AM »
Thank You Jeff,  yes.  For the C4 .  The mount seems to be a little mangled but possibly usable.  Will find out here in this summer.  Thanks for the number .
63D
250 six cyl.
C4 trans.
