Author Topic: 66 HiPo C4 Transmission Tail Shaft Extension Housing - Need Bolts!  (Read 850 times)
Offline Morsel
Does anyone have a source for these? AMK sells everything else out there but can't seem to locate the extension housing bolts for my C4...
Jason
Re: 66 HiPo C4 Transmission Tail Shaft Extension Housing - Need Bolts!
« Reply #1 on: May 15, 2018, 05:53:32 PM »
Got a part number?
Offline Morsel
« Reply #2 on: May 15, 2018, 06:18:04 PM »
Got a part number?
According to the assembly manual, it looks like 378784-S and has a lock washer... I also looked in your hardware excel doc...
Jason
« Reply #3 on: May 15, 2018, 07:26:11 PM »
Actually, it's in the service manual, the screw/bolt is not a serviced part (the star means not serviced), and is a 3/8-16X1 1/8 hex washer head, grade 2 (the washer head qualifies the item as a machine screw).
It looks like you are correct, no AMK. Do you have your originals?
Offline Morsel
« Reply #4 on: May 15, 2018, 08:09:55 PM »
Yeah, I have them, they're pretty beat up, but I'll just clean them up as best I can and re-use, no end of the world crisis here ;) Just was looking incase someone had a line on some...
Thanks for your help Jim...
Jason
Offline acman63
« Reply #5 on: May 16, 2018, 10:48:26 PM »
sendm e a picture of the bolts you have,  more than likely I have some   jim@shelbyparts.com
