Author Topic: 1965 code 22 medium blue poly  (Read 1379 times)
Offline kb65
« on: May 07, 2018, 08:58:08 PM »
Does any one know the formula to get this color correct.
My local paint supplier has tried 3 times and has failed all 3 times .
They have even scanned the color from an original interior panel.
ken
ken
Offline kb65
Re: 1965 code 22 medium blue poly
« Reply #1 on: May 08, 2018, 09:00:58 PM »
OK does anyone know where to get a quart of this color
npd claims to have the correct color in ppg  lacquer spray can but not quarts
ken
ken
« Reply #2 on: May 08, 2018, 09:55:35 PM »
Have you tried Auto Color Library/TCP Global that has been mentioned in a number of prior threads?
No connections to the company. I see that the state finally got after them for shipping certain paints (most) to instate customers. They are located in SoCal ::)
http://www.autocolorlibrary.com/
http://www.tcpglobal.com/
Check 1966 Ford pages also
Went through the process and they offer most types in paint (enamel, lacquer, urethane and urethane base coats) in gallons and quarts
« Last Edit: May 08, 2018, 10:06:01 PM by J_Speegle »
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« Reply #3 on: May 16, 2018, 10:01:50 PM »
med blue poly code  Ditzler #12989
« Reply #4 on: May 16, 2018, 11:06:20 PM »
Well at least that was the color code 50 years ago ;)
Offline DKutz
« Reply #5 on: May 16, 2018, 11:32:51 PM »
ken
I ordered my spray cans from another vendor, when I ran out I ordered a van from. NPD, it was an exact match to exsisting color found under dash and column strap.  So I would go NPD.  Of course if you want to have it in quarts...
Offline kb65
« Reply #6 on: May 17, 2018, 09:15:30 AM »
like Jeff said that was the code
tried the npd stuff it was not correct.
color library said they could make it for $107 per qt plus shipping but they don't show a sample and id did not want to spend that much and have it still be wrong.
ken
ken
Offline Bartman
« Reply #7 on: May 19, 2018, 08:14:51 PM »
Hi KB 65. I re did my interior with a full resto 2 years ago. I have #22 interior code, Aug.64.
My painter did an incredible job and matched the paint perfectly. He used PPG Acrylic 3852 base and a flat clear.
It was the same as ford used in later years as well.
Good luck. You will be impressed.
Bartman
