Author Topic: Smog pump parts?  (Read 2467 times)
Offline BigB427
Smog pump parts?
« on: September 24, 2010, 07:20:05 PM »
Is there a supplier of components to rebuild a smog pump out there that someone can recommend?
Is there some place that rebuilds your pump also?
Looking for options to repair my pump that locked up.
Formerly 69 Mach 1 428SCJ w/ 4:30 gears, 69 GT 500 convertible #0018, 69 Boss 429 KK1599, 67 GT500 #0784, and a few others
Offline fla2005
Re: Smog pump parts?
« Reply #1 on: September 26, 2010, 10:13:22 AM »
Give Cardone a call. Maybe they can help out.
« Reply #2 on: September 26, 2010, 11:22:07 AM »
You,open up the back and break the fins out and make it free wheeling. This is a old racers option that has been done since the cars were new so it can have the correct appearance. Of coarse it will not funtion as intended or have the horsepower drain but it will look correct. Just one possible option  . Bob
« Reply #3 on: September 26, 2010, 04:34:27 PM »
Offline BigB427
« Reply #4 on: September 27, 2010, 01:11:29 PM »
Thanks for the replies guys. I'll try Semo, but I'm not familiar with cardone. Do they have a website?
I believe my pump already has the fins removed.  It still locked up so it must be a shaft bearing problem. Is this common on these old smog pumps?
Offline sah62
« Reply #5 on: September 27, 2010, 03:48:14 PM »
Doug Herr at Factory Muscle Parts just rebuilt a pump for me.  It came out great, the price wasn't bad, and he did the job quickly.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #6 on: September 29, 2010, 01:27:57 AM »
The bearings going bad isn't quite as common as the fins or veins on the inside the case breaking . Bob
Offline fla2005
« Reply #7 on: September 29, 2010, 09:12:31 AM »
see www.cardone.com
Cardone is a major rebuilder and based in Philadelphia, Pa.
For DIY buy a Cardone rebuilt smog pump 32-116CV for about $100.00, and use the parts
in your existing pump. Or, use the rebuilt pump, if casting date etc isn't important, and add a new fan and control valve.
