Author Topic: 1966 Rally pac  (Read 3185 times)
Re: 1966 Rally pac
« Reply #15 on: May 07, 2018, 02:40:15 PM »
FWIW; I learned in an attempt to repair my 65 GT 6K tack  " parts are simply not available ".  Brian
Offline Hipo giddyup
Re: 1966 Rally pac
« Reply #16 on: May 31, 2018, 02:40:13 PM »
 I just wanted to follow back regarding my 66 low profile rally pac restoration. I stripped the gauge pods of all the prior paint and gave them a fresh coat of black wrinkle paint.  I then baked the wrinkle finish for approximately 10 minutes at 200°.  It turned out nice in my  opinion. I then masked the wrinkle paint  surrounding the inner area of the gauges, near the gauge faces, and painted this inner area a semi-flat black like original. I had sent my tac out to be repaired  and I was very pleased with the results. Since it has come back I have new wires installed and LED bulbs for long life.  I also replaced the original clock with a quartz movement.  I just finished installing the rally pac today and everything works as it should. . Very happy with the results.
Re: 1966 Rally pac
« Reply #17 on: May 31, 2018, 03:07:35 PM »
Nicely done!
Offline Morsel
Re: 1966 Rally pac
« Reply #18 on: May 31, 2018, 03:15:00 PM »
Looks great! Nice work...
Offline rocket289k
Re: 1966 Rally pac
« Reply #19 on: May 31, 2018, 03:36:57 PM »
Looks great - nice job
Offline Jack65K
Re: 1966 Rally pac
« Reply #20 on: May 31, 2018, 04:28:45 PM »
Looks good!
Jack
65 K Code Coupe, Vintage Burgundy/White Vinyl Top & Black Interior
04 GT Convertible, Redfire Clearcoat/White Top and Oxford White Interior
Re: 1966 Rally pac
« Reply #21 on: May 31, 2018, 05:16:55 PM »
Thanks all. Couldn’t have done it without the help from this forum. Special thanks to midlife for answering my wiring questions. :D
One other comment I forgot to mention.  When I purchased this rally pac the center had a hole drilled through it which was likely use to help attach it to the steering column. I actually filled the hole with short strand fiberglass and sanded it smooth just like I was doing bodywork on a car. It worked out great.
Re: 1966 Rally pac
« Reply #22 on: May 31, 2018, 08:50:04 PM »
Yes, looks very good. Is your short strand fiberglass Duraglas?
Re: 1966 Rally pac
« Reply #23 on: June 03, 2018, 11:43:23 PM »
Close, it’s called dynaglass. I have had great success with this product, with many different uses.
Re: 1966 Rally pac
« Reply #24 on: June 04, 2018, 08:24:44 PM »
Dynatron Dyna-glass vs USC Duraglas. Same kind of stuff -- different vendor.
Both are epoxy based; both have kitty hair and both are waterproof.
You're right --- a lot of different uses. Good stuff.
Re: 1966 Rally pac
« Reply #25 on: June 05, 2018, 10:13:37 AM »
yep....patched my old shop trashcan with some of that stuff years ago. still holding just fine.
