Author Topic: 1965 HiPo motor mounts  (Read 764 times)
Offline evantugby
« on: May 01, 2018, 12:19:46 AM »
Gents,
Question:  Are these the correct nuts to thread onto the bottom of the motor mounts?  They are really tight to put on (even with a ratchet) and have a very small bend in both of them, each bend appearing consistent between the two nuts.
Question 2:  Does this minor bend on each nut serve some sort of safety purpose to prevent the nut from coming off the bolt?
Re: 1965 HiPo motor mounts
« Reply #1 on: May 01, 2018, 02:15:39 AM »
Gents,
I think the nuts have the wrong thread. This is a problem with the nuts AMK sells . If you tighten them all of the way down you cross thread the stud. Others as well as myself have experienced the same thing . The style of nut is correct but the thread is wrong. Just the way it is . Complain to them. I don't know if they sell the nut with the correct thread or not. I ended up re plating original nuts. Yes, it is a locking nut.  The squeeze shape of the nut is design to lock it in place.
Offline evantugby
« Reply #2 on: May 01, 2018, 02:47:35 PM »
Oh Wow!  Okay.  Well glad I asked before I started forcing the nut on to the stud.  Thanks Bob!
I sent off an email to sales@amkproducts.com along with pictures and a description of the issue.  I am waiting on the owner to get back with me on this problem.
« Last Edit: May 01, 2018, 03:09:59 PM by evantugby »
Offline FastLaneMustang
« Reply #3 on: May 02, 2018, 11:53:30 AM »
I had the same problem - I talked to them and they sent the correct nuts.
« Reply #4 on: May 02, 2018, 12:23:24 PM »
Did you check the 64-66 Hardware Spreadsheets in the Forum's library?
