Author Topic: Throttle Cable and Coil Brackets  (Read 2067 times)
Offline 1970 Snake
« on: April 29, 2018, 07:04:45 PM »
Can someone please advise the correct color and finish of the throttle cable bracket and the coil mounting bracket on a 1970 428 CJ R-Code Dearborn built mustang.
Also would like to know if the intake air filter housing bracket that comes off the engine is black or Ford blue?
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline cobrajet_carl
Re: Throttle Cable and Coil Brackets
« Reply #1 on: May 01, 2018, 02:39:45 PM »
I'm not positive mine are original, but the coil and throttle brackets look like P&O while the shaker bracket looks like black paint.
Carl
70 and 71 Dearborn mach Is
« Reply #2 on: May 01, 2018, 07:24:35 PM »
A picture from the following thread might help you out
http://www.concoursmustang.com/forum/index.php?topic=10002.new#new
So that should answer the coil bracket and the shaker to intake support. The throttle bracket from my understanding would also typically be P&O
Offline Mike_B_SVT
« Reply #3 on: May 02, 2018, 07:05:20 PM »
There was a recent discussion on the 428CJ forum about the 70 CJ throttle bracket.  P&O for originals, and it appears that service replacements were painted black.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #4 on: May 02, 2018, 08:08:13 PM »
There was a recent discussion on the 428CJ forum about the 70 CJ throttle bracket.  ...........
Thanks Mike saw the discussion and it help support what I was finding in my records
« Reply #5 on: May 04, 2018, 05:25:34 PM »
I can't really tell from the pic but are you saying the shaker bracket is also P&O?
Carl
« Reply #6 on: May 04, 2018, 05:40:16 PM »
This help?
Appears to be semi-gloss black (may be dipped) finish, to me
« Reply #7 on: May 04, 2018, 05:45:43 PM »
OK, so I guess mine is correct then. ;) Although I can't tell if dipped or sprayed or gloss. Funny what 48 years will do...
Carl
Offline 1970 Snake
« Reply #8 on: May 08, 2018, 07:14:00 PM »
Thanks for all the input guys, I suspected the coil and throttle brackets where P&O but wasn't sure about the shaker support bracket, but will be finishing it in semi-gloss black.
