Author Topic: battery cable sleeve  (Read 561 times)
« on: April 29, 2018, 12:17:54 PM »
the + red sleeve near the solenoid end on my battery cable has cracked. the rest of the cable is just fine. where can i obtain the off red sleeve material to repair this?? thanks.
Re: battery cable sleeve
« Reply #1 on: April 29, 2018, 12:43:50 PM »
As far as I can tell, you can't. I had the same problem. I replaced the cable. In order to get just the sleeve, the ring lug has to come off and get replaced. Shrink tubing might work, but is too thin.
« Reply #2 on: April 29, 2018, 01:06:02 PM »
don't think you can just buy the + cable itself. all i have seen come as a set with the - cable & starter cable. don't need those.
« Reply #3 on: April 29, 2018, 01:54:54 PM »
You can. They will send you the cable but charge you the full price.
« Reply #4 on: April 30, 2018, 11:20:58 AM »
Maybe give Marti Autoworks a ring and ask if they would sell one separate.  Might also check with Brant at Va Mustang.
