Author Topic: Autolite 4100 Carburetor is very clean and in great shape  (Read 1606 times)
Offline Fordman265
« on: April 22, 2018, 10:58:41 PM »
Autolite 4100 Carburetor is very clean and in great shape, but will need a rebuild kit (needle valves are missing)
Body numbers: C5ZF D
Casting number on bottom: 7-27-64
1.08 venturi   Primary jets: 46F   Secondary jets: 57
Automatic choke and dashpot
More pictures available or I will take what you want to see
Archie
(303)901-3282
abaj1@msn.com
« Last Edit: May 04, 2018, 01:22:40 AM by Fordman265 »
64.5 Conv 289 C4 9" built May 21 in Dearborn
64.5 Pre-production Conv 05C #139 F-code C4
Re: Autolite 4100 Carburetor is very clean and in great shape
« Reply #1 on: April 23, 2018, 12:30:13 AM »
Top tag: C5ZF H (H has been scratched out and D hand scribed. Not sure this tag is original to this carb)
A C5ZF-H carburetor is a 2100. It should be C5ZF-D. You're correct, the tag is not original.
The casting number, 7-27-64, is on a lot of 4100 in the 65 time period. The tag would have the carburetor's assembly date.
- but will need a rebuild kit (needle valves are missing)
The originals were steel, replacements are brass. They work fine, just not concourse correct.
Offline Fordman265
« Reply #2 on: April 23, 2018, 10:43:20 PM »
Thanks for the information Jim! I will remove the tag from the carb.
Offline markb0729
  • South Jersey
« Reply #3 on: April 23, 2018, 11:20:56 PM »
For that kind of money, your C5ZF-D carburetor should have the correct primary and secondary boosters.  Many have been rebuilt over the years and have the incorrect boosters.  The primary booster should be stamped "CH" and the secondary booster should be stamped "A".  You have to take the boosters out to check the stampings.  I would not pay that kind of money without confirmation.  It would cost another couple of hundred dollars to restore.  That carb is worth $250 at best if everything checks out.
« Last Edit: April 23, 2018, 11:25:05 PM by markb0729 »
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Offline Fordman265
« Reply #4 on: April 26, 2018, 12:36:00 AM »
I will check the boosters this weekend and post pictures of what I find.
Offline Fordman265
« Reply #5 on: April 26, 2018, 03:59:23 PM »
Here are the pictures of the two boosters. First is primary and second is the secondary.
Offline Fordman265
« Reply #6 on: May 04, 2018, 01:23:20 AM »
Carb is no longer for sale.
Offline Fordman265
« Reply #7 on: May 05, 2018, 12:46:08 AM »
Thanks for the information. Where can I learn which boosters belong in which 4100 carb?
« Reply #8 on: May 05, 2018, 05:16:52 PM »
Topic split rather than continue in the For Sale section
It can be for here ;)
http://www.concoursmustang.com/forum/index.php?topic=18110.msg114611#new
