Author Topic: 1966 arm rest pads  (Read 871 times)
Offline Hipo giddyup
1966 arm rest pads
« on: April 22, 2018, 01:09:53 PM »
I just purchased an original pair of very nice, but used,  black 1966 armrests. I replaced my current repro set using these with NOS bases. The issue I have is that the ends curve up slightly leaving a gap. Is the any way to prevent this ??
Re: 1966 arm rest pads
« Reply #1 on: April 22, 2018, 04:38:34 PM »
A couple of points and questions: - Used means used. - Do the pads have the Ford part number on the mounting side? Ford pads have an extra internal support to reduce, if not eliminate, the "curve". The "curve" means you need new pads.
« Reply #2 on: April 22, 2018, 06:23:56 PM »
Yes, Ford part numbers molded into the vinyl. They lay flat on a table but once mounted, there is a gap. I tried backing off a bit on the screws but I don’t want it that lose.
« Reply #3 on: April 22, 2018, 08:05:23 PM »
I'm sorry to say, keep looking.
« Reply #4 on: April 22, 2018, 10:53:35 PM »
Rats. Well they only cost me $10.  :-\. I guess I’ll look for an NOS set. Thanks Jim
« Reply #5 on: April 24, 2018, 05:55:56 PM »
There's a metal plate inside of them, you might try bending it upward in the middle area to help level it out when tightened.
« Reply #6 on: April 25, 2018, 05:03:38 PM »
 Good point Charles. I wasn't aware if that was possible. Mine look and feel much better than the repros with the exception of the 1/8" gap at the ends.  ;D
