Author Topic: J-Code Motor  (Read 5364 times)
Offline DTruitt
J-Code Motor
« on: August 31, 2009, 05:59:19 PM »
Here are a few pictures of a '68 J-code motor I recently rebuilt (with a friends help) and detailed.  I believe it to be concours correct however, we can discuss any thing that people think otherwise.
Picture as removed from car:
Another as removed from car:
Here is one as it is installed in my cousin's '68 GT.  Although I detailed the engine to concours the car is not currently to those standards and probably won't ever so don't pick on the surrounding engine compartment and such.
« Last Edit: August 31, 2009, 07:46:52 PM by DTruitt »
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
Offline DTruitt
Re: J-Code Motor
« Reply #1 on: August 31, 2009, 06:05:22 PM »
Oops, I messed something up.  I'll try to resize later.
Danny
MCA Gold Card Judge
Offline cmayna
Re: J-Code Motor
« Reply #2 on: September 08, 2009, 10:59:15 AM »
Danny, though I am NOT a concours minded sole, it looks like you did a great job on that Jcode.
Offline gtamustang
  • CPM
Re: J-Code Motor
« Reply #3 on: September 10, 2009, 02:45:19 PM »
Hope you changed out that late model water pump! Also, the vaccum advance on the distributor is aftermarket.
Engine color looks very nice. As a "next level" consideration, not all of the valve cover bolts get painted. Typically only the top outside 2 per side were installed when the motor was painted. Of course this varied from engine plant to engine plant.
Regards,
Pete
Offline DTruitt
Re: J-Code Motor
« Reply #4 on: September 10, 2009, 06:35:19 PM »
Pete,
The water pump on the rebuilt motor is the correct casting # pump, unless there are later and earlier versions with the same casting number.
I could not find anything to indicate only certain valve cover bolts were painted.  I will say some did not have paint on them while others did.  All the original wiring and vacuum clamps on the valve covers had evidence of paint.  So I deducted that all the valve cover bolts were installed when the motor was painted, although because of the plating on the bolts paint adhered to some better than others.  I understand some believe only a portion of bolts were on the motor when painted, but I could not find any factory documentation to support that.  What evidence or documentation do you have that indicates differently (trying to learn/ confirm)?
On some of the "new" valve cover bolts with fresh paint, the paint did not adhere and has flaked off a couple of the bolts.
You are absolutely correct about the vacuum advance!
Thanks for the comments.
MCA Gold Card Judge
Offline gtamustang
  • CPM
Re: J-Code Motor
« Reply #5 on: September 11, 2009, 10:37:53 AM »
My error on the water pump; it appeared as the late model replacement at a quick glance. Re-looking, I see the support ribs signifiying a C6xx or C8xx engineering number type.
As for the some of the valve cover bolts not being painted, my documentation is my experience with 67-68s, discussions with Kevin Marti (he has a few original engine assembly pictures), and of course, discussions with the ever popular Jeff Speegle.
Regards,
Pete
