Author Topic: 65 info needed San Jose build (not 64.5)  (Read 1746 times)
Offline KevinK
« on: April 17, 2018, 01:11:37 AM »
I'm looking at a coupe vin 5R07C150xxx. It's for sale locally thru a friend. I did a little research on the differences from the 64.5 tp 65.
Generator, no
Folded hood edge, no
Oil wicked distributor, no
Louvered radiator support, no
Clip on door handles, yes
Carpeted rocker panel, yes
Colored lock knobs, yes
Seat belt eye bolt, no
Vent knob under dash, yes
Tail light wiring pig tails, no
Lug wrench, unknown
Spare hold down bolt, carriage type, yes
Long speedo, yes
Large horns, no
Brake switch on master cylinder, no
Wheel covers, unknown
Easton power steering pump, yes
Cast iron water pump pulley, no
Painted hood hinges, unknown
Phillips head hood bumpers, yes
Large voltage regulator, no
Door tag, missing
Are there any other sources to read up on more details? Clearly the vin falls within the 64.5 range as the first 50,000 cars. Looks like the engine has been replaced. No tags on the carb. Intake is C6. That's about all I know so far. Body is decent, some small,dents and a 2" rust spot on the drivers door. Has not been started in 9 years. Any idea on a value. Thanks for any input.
Any pictures of what the door tag should look like?
« Last Edit: April 19, 2018, 01:07:20 PM by KevinK »
MCA #33800, Gold Card 3rd Gen
BAMA Member
Re: 64.5 info needed San Jose build
« Reply #1 on: April 17, 2018, 08:42:59 AM »
VIN clearly indicates that this is a 1965 (not 64.5) model.  The change-over from 64.5 to 65 was at 125000
« Reply #2 on: April 17, 2018, 10:18:03 AM »
San Jose didn't start building Mustangs until sometime in July '64, while Dearborn had been building them since March '64.  Each assembly plant used their own unit numbers, they weren't shared.  This is why unit number 150xxx would fall during 64.5 production at Dearborn, but not at San Jose.
Offline ChrisV289
« Reply #3 on: April 17, 2018, 02:36:16 PM »
I would say it's build date is probably around mid to late of October 64. Mine is 152xxx and is 29K
2009 V6 Mustang Coupe
Offline KevinK
« Reply #4 on: April 17, 2018, 04:25:39 PM »
Thanks for the replies. I did not consider how the other plants factored into the 64.5 production numbers.
Does the 65 door tag look similar to the 67-69 door tags?
I don’t think it will take much to get it running. Is $5000. A good price?
Non original 289, auto and flat paint. Some pieces are present for the console.
BAMA Member
« Reply #5 on: April 17, 2018, 07:17:55 PM »
It's more complicated than that. There's this little thing called "running changes". That makes it more difficult
Nope. The 65 is different from the 66 as well. You can get a reproduction from Marti Auto http://www.martiauto.com/
Don't expect that you can stick with a budget.
See above.
Offline KevinK
« Reply #6 on: April 17, 2018, 08:13:39 PM »
Actually, the question “I don’t think it will take much to get it running. Is $5000. A good price? “
I was asking if it was worth buying for $5000 if I can get it running and moving under it’s own power.
BAMA Member
« Reply #7 on: April 17, 2018, 08:27:39 PM »
Offline KevinK
« Reply #8 on: April 17, 2018, 08:52:27 PM »
Thanks Jim.
Thanks Jeff.
BAMA Member
Offline KevinK
Re: 65 info needed San Jose build (not 64.5)
« Reply #9 on: April 19, 2018, 01:18:45 PM »
Any suggestions on the car's value as is?  A quick glance has a parts list of $1500 and this is if it will start and run as is.
I did some looking around and there is not a whole lot out there between the rust buckets and the $15K plus cars.  Lots for $25-35K.  One of the pricing guides put a running driver at $6900.  This is not that good yet.  Has some dings, some filler, radio is MIA, dash pad loose,  all original glass in good shape.  One rust spot on the door and the gas tank looks rusty.  The passenger floor has been kind of patched with a regular floor panel.
Suggestions on value? Trying to decide if I should pass on it.
BAMA Member
« Reply #10 on: April 19, 2018, 02:14:09 PM »
I'd offer about $3500, but not go above $4k.
Offline KevinK
« Reply #11 on: April 19, 2018, 03:26:22 PM »
Thanks.
I wanted to think it was worth more than $5000. Common sense and the math do not add up.   I think you are on the money.
« Last Edit: April 19, 2018, 11:31:58 PM by KevinK »
BAMA Member
« Reply #12 on: April 19, 2018, 04:06:49 PM »
Consider that a concours example of a 65 C code coupe is probably maxed out around $20-25k.  You can go backwards from there if your goal is concours.
