I haven't tried this variety yet, as I still have a tube of the silver stuff (which lasts forever) but you might consider using it when you do your install of these plugs:https://www.permatex.com/products/lubricants/specialty-lubricants-anti-seize/permatex-copper-anti-seize-lubricant/If you need to extract these little buggers for any reason later on, you'll thank yourself I think...just make sure you put it on the threads only and not over the tips. It probably would just burn off but neatness/caution counts often times.
