Author Topic: 69 NJ Sportroof questions  (Read 1433 times)
Offline qman
« on: April 08, 2018, 09:55:21 AM »
My 1969 May built Metuchen sports roof came to my home in boxes. I'm getting closer to finishing the car up and have a few questions....so here goes:
1. Did all 1969 Mustangs come with a day/night mirror?
2. How was the emblem on the shaker attached was it an adhesive or mounted with fasteners?
3. If mounting the emblem was with adhesives was there a template used?
Probably have more questions as we put the car back together.
Thanks again
Qman
« Last Edit: April 08, 2018, 04:51:44 PM by J_Speegle »
Offline 7Lscjracer
Re: 69 NJ Sportroof questions
« Reply #1 on: April 08, 2018, 05:27:15 PM »
Bought May '81, sold Sept '20
Offline 7Lscjracer
« Reply #2 on: April 08, 2018, 05:46:13 PM »
So are you adding a shaker to a Q code car?
It's a late build so if it was a real R code it would have had just have the cobra jet script on the scoop and not a 428 badge too.
The script is too long and skinny for fasteners so it's adhesive backed.
http://www.2040-parts.com/nos-1969-1970-mustang-mach-1-428-cobra-jet-c9zz-16720-a-oem-shaker-scoop-emblem-i22781/
I don't know if there's a template, but interweb pics sure do show inconsistency in placement.
« Last Edit: April 08, 2018, 05:50:59 PM by 7Lscjracer »
« Reply #3 on: April 08, 2018, 06:14:33 PM »
Ford may have designed a template for the workers (never heard or seen one) but if they did its likely IMHO the worker quickly just did it by sight and habit
Offline 7Lscjracer
« Reply #4 on: April 08, 2018, 06:52:17 PM »
Might as well stick it on as pictured here:
« Reply #5 on: April 08, 2018, 07:04:13 PM »
Rather than using an ad  here are a couple of original NJ examples that show the variations of locations - possibility the results of two different installers
First from the 9T149xxx
And one from the 9T219xxx
Offline qman
« Reply #6 on: April 08, 2018, 08:15:42 PM »
Thanks for the help.
Qman
Offline rayms69
« Reply #7 on: April 09, 2018, 11:20:14 AM »
I used 3m adhesive tape, works great. I centered the scripts to hide the the left from removing the 428 emblems, a little trial and error and redos to get it looking good.
« Last Edit: April 09, 2018, 11:22:45 AM by rayms69 »
10-26-1969 Dearborn 428 SCJ auto
Offline 1970 Snake
« Reply #8 on: April 10, 2018, 01:30:22 AM »
I hope this will help, I took these measurements 30 years ago off my original untouched factory shaker. I wanted to paint it at the time and decided to remove the badges to do that, as I had several NOS sets of Cobra Jet badges and wanted to make sure the new ones went back on in the correct location. Believe it or not this piece of paper has been stuck to the side of my toolbox for that long, goes to show how well sticky notes actually hold on. And FYI these measurements are off a Sept 69 Dearborn built 1970 Mach1.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
