Author Topic: 1966 disc brakes  (Read 1043 times)
Offline Hipo giddyup
1966 disc brakes
« on: April 06, 2018, 03:09:08 PM »
 I am contemplating adding original disc brakes to my 66' coupe. I had a few questions that I am unsure of. First, I am using original 66' styled steel wheels. Can I assume that these would have no issue being used with disc brakes?? Secondly, am I correct in that every disc brake car had a proportioning valve?? And if so should I find an original or would a,  (dare I say it), aftermarket  :-[ work fine with the original disc brakes??
Thanks for a reply.
Re: 1966 disc brakes
« Reply #1 on: April 06, 2018, 03:15:50 PM »
The styled steel wheels will clear the disc brakes.
Yes every factory disc brake car had a proportioning valve
Yes you can use an aftermarket - but it will stand out in an otherwise stock looking car. Would not recommend (heck look what site we're on ;)  anything other than a factory like one. IF your considering making "improvements" might as well toss the master cylinder, then the ...........  ::)
« Last Edit: April 06, 2018, 03:18:10 PM by J_Speegle »
« Reply #2 on: April 06, 2018, 04:33:39 PM »
 Thanks Jeff. Not trying to offend the purists here but I can't even come close to stopping like the other folks with their modern cars so since I will be driving this car often I feel the need for braking improvements. I want to keep the appearance as close to "original" as possible so I will see if I can locate/afford a rebuilt original. I already made the change to a dual master cylinder for safety reasons.  :(
One other question, are there specific "disc brake" spindles or will the V8 brake spindles interchange?
« Reply #3 on: April 06, 2018, 04:46:48 PM »
Thanks Jeff. Not trying to offend the purists here but I can't even come close to stopping like the other folks with their modern cars so since I will be driving this car often I feel the need for braking improvements. ..............
Its not about offending anyone here - it's about our focus.  Plenty of other places that focus more on trying to make these old cars "safer" and so on.  :)  No matter what you do their not going to be like new cars as far as safety. In general terms
Believe you will find no fit issues
« Reply #4 on: April 06, 2018, 05:02:07 PM »
-  (dare I say it), aftermarket  :-[ work fine with the original disc brakes??
Original Ford Style Steel Wheels should clear. About 15-20 years ago, there was an interference fit with aftermarket SS wheels and Ford factory disc brakes. I would think that those wheels are now few and far between. Just a heads up.
« Reply #5 on: April 06, 2018, 05:14:26 PM »
Thanks for that info Jim!
