Author Topic: 65 fastback courtesy light wiring route  (Read 661 times)
Offline FastLaneMustang
« on: April 03, 2018, 09:34:46 AM »
Does anyone know the route the wiring takes to get to the courtesy light in the passenger quarter panel of a '65 fastback?
« Last Edit: April 03, 2018, 05:55:45 PM by J_Speegle »
Re: courtesy light wiring route
« Reply #1 on: April 03, 2018, 01:53:51 PM »
There's the tail-light harness that has an outlet of the black/blue wire for a female bullet.  Into that is the harness that goes to the driver's side courtesy light, along with another female bullet.  A third wire plugs into that and routes behind and below the rear window over to the passenger side, ending up in a female bullet.  The passenger side courtesy light harness plugs into that as well as a grounding point.
« Reply #2 on: April 03, 2018, 04:46:53 PM »
I recommend that you get a set of Mustang Assembly Manuals for your car's year. You question was answered there.
Re: 65 fastback courtesy light wiring route
« Reply #3 on: April 03, 2018, 06:29:54 PM »
Would be helpful if you included when and where the car was built as details can and often do vary. ;)
« Last Edit: April 03, 2018, 09:44:20 PM by J_Speegle »
« Reply #4 on: April 03, 2018, 09:24:55 PM »
Thanks for everyone's input.  I do have the assembly manuals but I couldn't find this wires route.  I'm sure I just missed it.
Jeff, my car is a Metuchen June 11, 65 build.  Does that change things from the picture you posted?  I know you had said my fuel sending wire actually goes into the interior and thru the trap door into trunk across tank and back outside.
« Reply #5 on: April 03, 2018, 09:47:54 PM »
Yes it likely does change but can't confirm since I don't have any pictures of that area for your car's plant and production period
Pulled the pictures and placed them in another thread
