Author Topic: Ford Thompson Pump  (Read 6153 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Ford Thompson Pump
« on: September 18, 2010, 02:37:15 PM »
Does Anyone have any pictures of a well detailed teal power steering pump and pulley and bracket w/bolts, for a March 1966 C-Code Metuchen car with A/C?
66 Metuch Conv
Nightmist, Std Blu Int
Offline ChrisV289
Re: Ford Thompson Pump
« Reply #1 on: September 18, 2010, 03:50:07 PM »
I have a 65 A code, does that help?
2009 V6 Mustang Coupe
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: September 19, 2010, 10:54:47 AM »
I'd like to see them, but It's black I think.  I really want to see the teal one.
66 Metuch Conv
Offline ChrisV289
« Reply #3 on: September 19, 2010, 11:19:32 AM »
Let me know if these help and if you need pics of something else I can go take it:
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: September 19, 2010, 02:21:46 PM »
Thanks a lot!  I THOUGHT the 65 ford pumps were always black?  MIne is a 66 so I know it's teal.
So the dataplate tag is painted? And I see the whole front casting is painted, not natural?
Are the water pump bolts painted?  Black or Corporate Blue?  I think with PS, you discard the thick water pump bolt washer, right?
What determines if the small diameter pipe with a Dairy Queen curly-Q dipstick or the large diameter one with 1/4-turn big cap dipstick is used?
66 Metuch Conv
Offline ChrisV289
« Reply #5 on: September 19, 2010, 02:32:18 PM »
My understanding is that that 65 could be teal or black depending on certain things.  I think mine is supposed to be black but I bought this off ebay already done.  The filler neck is suppose to be that large on 65-66, the smaller neck didn't start until 67 I believe.  It actually had a 67 pump on this car when it was bought in 92 and I believe the first or second owner probably had it changed out because the original went bad.  I'll never know if it had the eaton power steering pump or the ford pump originally.  It is an early fastback built 10-29-64.  I would assume the water bolt pumps would be blue on your car if it is a 66.
« Reply #6 on: September 25, 2010, 02:48:25 AM »
The color of the pump depended on the supplier (Ford or TRW) The tag on the rear tells you the supplier.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #7 on: September 25, 2010, 10:58:48 AM »
If the tag is missing, how do you tel which?
The Mannel book doesn't say I don't think.
66 Metuch Conv
« Reply #8 on: September 26, 2010, 02:57:06 AM »
Do not know of any other method of identification - and none of the TSB articles I have give any clue other than the tag
« Last Edit: July 02, 2020, 06:40:00 PM by J_Speegle »
« Reply #9 on: September 26, 2010, 11:30:12 AM »
Just to add to Jeff's reply- Ford Thompson= Blue . TRW = Black. Bob
Offline ChrisV289
« Reply #10 on: September 26, 2010, 01:13:23 PM »
What would the tag say on which supplier?
« Reply #11 on: September 30, 2010, 02:33:58 AM »
Guess I should have been more complete with my answer
So if you will look at the FAQ's of the sections you will find in the
" GENERAL FAQ’s that apply across categories and sections."
It was included there since this has been a very popular question since the internet first became available to us regular fokes
You will find Question #7 withe a complete response ;)
One of the locations
http://www.concoursmustang.com/forum/index.php?topic=4.0
« Last Edit: September 30, 2010, 02:46:58 AM by J_Speegle »
Offline ChrisV289
« Reply #12 on: October 05, 2010, 10:58:29 PM »
Guess I don't have to worry about painting my pump black since it has an F in the middle line indicating it's a Ford Thompson - teal
HBA AD
   1F
5D21B
Offline bryancobb
  • 2009 Ridn' Around
« Reply #13 on: October 06, 2010, 07:45:20 AM »
Just a shot so I can see water pump and crank pulleys and belts...
I would greatly appreciate!
66 Metuch Conv
Offline ChrisV289
« Reply #14 on: October 06, 2010, 09:32:22 PM »
Let me know if this helps:
