Author Topic: 1966 289 alternator lower adjustment bracket with A/C idler pulley  (Read 1295 times)
Offline socalgt
Is the lower bracket that the adjustment bolt attaches to different for a non smog car(with a/c idler pulley) as with smog?  I replaced the special alternator mounting bracket with smog and installed the standard bracket and a/c idler pulley, and now the alternator fan hits the lower bracket.  I wasn't aware there were different lower brackets.  Can't think of another reason the fan would now contact it.
« Last Edit: March 15, 2018, 11:36:22 PM by socalgt »
Offline socalgt
Re: 1966 289 alternator lower adjustment bracket with A/C idler pulley
« Reply #1 on: March 16, 2018, 02:15:26 PM »
I put a new, slightly bigger belt on....evidently the wrong size belt can allow the alternator to be in a positioned to have the fan contact the bracket when tightening the belt....I thought any position within the adjusting slot on the bracket would work...guess not.
Offline socalgt
« Reply #2 on: March 16, 2018, 09:07:14 PM »
Well....that didn't fix the interference.  Attached are pics of the adjustment bracket.....in case someone sees something I don't.  There was no interference before I exchanged the special smog alternator bracket for the a/c idler pulley alternator bracket.....the slotted adjustment bracket was fine before with no interference....no changes to the alternator, other than mounting it the standard way with the long bolt and spacer rather than using the "smog" alternator bracket......running out of ideas.
        Thanks...
Offline socalgt
« Reply #3 on: March 16, 2018, 09:12:11 PM »
Looked for original alternator adjustment braces on line and if I'm not mistaken, this is not correct and I assume accounts for the interference....?
Offline socalgt
« Reply #4 on: March 16, 2018, 09:24:51 PM »
Yep.....looks like the wrong bracket....didn't think the slotted adjustment brace would be different for smog and non-smog cars......boy, I've never answered my own posting so many times, any way, appears the problem is solved.
« Reply #5 on: March 16, 2018, 09:30:14 PM »
According to the MPC, the T/E version you need to look for part number C6OZ-10415-A.  What's on the picture is the engineering or casting number.
« Last Edit: March 16, 2018, 09:37:28 PM by midlife »
« Reply #6 on: March 16, 2018, 09:34:22 PM »
Another source says you need part C6OZ-10145-A, casting C6OE-10145-A.  Looks like the correct part for T/E.  The non-T/E would be C5AE-10145-C, casting C5AE-10145-A.
« Last Edit: March 17, 2018, 02:30:03 PM by midlife »
Offline lancelot66
« Reply #7 on: March 17, 2018, 12:16:51 PM »
I can definitely concur that the bracket you have is for a T/E setup. Mine is exactly the same. I just did a search on eBay and there are several of the C5AE brackets for sale right now, various conditions:
https://www.ebay.com/itm/65-66-Ford-Fairlane-Comet-Mustang-289-Alternator-Adjusting-Bracket-C5AE-10145-A/221638119635?hash=item339aa950d3:g:08AAAOSwCdNZbtcV&vxp=mtr
One of these should get you the results and correctness you're looking for.
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
Offline 196667Bob
« Reply #8 on: March 17, 2018, 12:56:57 PM »
Another source says you need part C6OZ-10415-A, casting C6OE-10415-A.  Looks like the correct part for T/E.  The non-T/E would be C5AE-10145-C, casting C5AE-10145-A.
Randy : I think you had a couple of "dyslexic moments" : 10145, not 10415. Please correct.
Bob
MCA 04909
« Reply #9 on: March 17, 2018, 02:30:39 PM »
Done.  Kanth you!
