Author Topic: Brake master cylinder components.. Proper name/availability.  (Read 5223 times)
Re: Brake master cylinder components.. Proper name/availability.
« Reply #15 on: March 07, 2018, 08:17:12 PM »
The NAPA here close claimed there are NONE to be had, as did O'Reilly.  There are few real parts stores anymore.  The rebuild on my booster also has me less than thrilled. I spoke to Booster Dewy and he claims he can make them function better in low vacuum environments. So I will overnight the booster to him while I refurbish the Bendix Master.
Speaking of trash, I purchased replacement rear wheel cylinders from O'Reilly. When I went to bleed them the bleeders were made with a metal so soft I rounded them off on both sides just breaking them loose with a line wrench. Chinese trash!
I know your build goes back and forth between assemblyline and personalization but thought I would mention that NPD sells a bleeder designed for use with the modern larger bleeders and has machined the wrench side portion to have the appearance of the smaller assemblyline bleeder. This gives the original look when using a auto parts store wheel cylinder. Just thought I would mention it.
1967 eight barrel
  • Guest
« Reply #16 on: March 08, 2018, 08:41:31 AM »
Bob Gaines:
I ordered the bleeders this morning! Thank you!.  You know I used to buy Wagner. I don't even know if they are in business anymore. I finally got a set of the correct nails for the rear shoes and I didn't have to compress the hold downs at 90 PSI to get the retainers on!
Thank you all for the pointers and help!
                                                               -Keith
1967 eight barrel
  • Guest
« Reply #17 on: March 09, 2018, 11:19:39 AM »
Is there a difference between the master for power Disc/drum and just power drum? The MK488 is what they shipped me. I see MK549 in the link above.
Offline 196667Bob
« Reply #18 on: March 09, 2018, 12:52:43 PM »
Absolutely different. The Power Disk/Drum MC used Bendix casting # 2227161, while both the Power Drum and Manual Drum used the same casting # 2227061 (as I described in my previous Reply). Thus, the Raybestos Kit for Power Disc/Drum is MK 549, while the Kit for Power Drum is MK 488.
Bob
MCA 04909
1967 eight barrel
  • Guest
« Reply #19 on: March 09, 2018, 12:59:59 PM »
Rock auto didn't specify. Just listed power. I guess I'll be returning it.
« Reply #20 on: March 09, 2018, 02:17:33 PM »
If you are ONLY needing the seats, you may still be OK
1967 eight barrel
  • Guest
« Reply #21 on: March 09, 2018, 08:45:01 PM »
Rich, I went ahead and pulled the trigger on Amazon. No since in throwing away the rest of the kit.
Offline 67350#1242
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #23 on: March 10, 2018, 12:16:52 PM »
Bob
Yes, I can confirm the DRUM version master cylinder from a power brake conversion kit I have on hand, has indeed the 2227061 casting. Pictures posted in a FOR SALE ADD today.
Offline 196667Bob
« Reply #24 on: March 10, 2018, 02:38:16 PM »
Keith : I think you made the correct choice. Not just because of the fact that you'd be throwing away perfectly good internal parts that you couldn't use, but also because of the seats themselves. In your specific case, it sounds like you have your known original Master Cylinder, and would thus be able to confirm that the Kit seats matched those in your existing MC. However, for others reading this thread, that may not be the situation. Case in point ; on my '67,  which my Dad purchased from the original Owner in 1981, at some time, the original MC was replaced ; either by the PO, or even possibly by my Dad (although I don't remember him doing so). I, wanting to replace the Wagner MC with the original Bendix one, sought to find an original Bendix casting. In my case, with original Drum brakes, I was also going to add the Optional/ Accessory Booster. As I noted previously, the Manual Drum Brakes and the Power Drum Brakes both used the same 2227061 casting. I purchased one from one of our members a couple years ago, and when disassembling it, compared the parts with those furnished with the original C7ZZ Kit that I had, as well as with those on the Raybestos Kit. All of the parts in the two Kits seemed identical, while the tube seats were slightly different ; the orifice size in the C7ZZ Kit being 0.0116", and those in the Raybestos Kit being 0.110". However, the seats in the MC that I had purchased, were 0.089". While 0.021" diameter may not sound like much difference, since pressure is a function of Force divided by Cross-sectional Area, this could  make a difference of almost 35% in the resulting pressure. While this may or may not affect how the system actually functions, one would think that you would want to replace seats that had an orifice size at least close to the original ones.
Being curious, I wanted to find out just what application(s) this Bendix casting (2227061) might have had. The source I had, showed that this casting was used on 1967-72 Fords and Mercurys, and 1967-73 Fords and Mercurys, with the two applications showing different Master Cylinder assembly Part Numbers ; one for Manual Drum Brakes, and the other for Power Drum Brakes. Based on this, plus the fact that the used MC that I purchased came with a rubber boot and brake push rod, I concluded that it must have come from a Manual Drum Brake application, Mounting and tube nut sizes for the lines were identical in both cases.
While checking on castings, I also decided to check on the one used for 1967 Mustang Power Disk Brakes (2227161). In this case, things become more complicated, especially if one does not have a known original with which to compare (thus the reason for this long Reply). The 2227161 casting was used on 1967-72 Mustangs, 1967 Ford Trucks, 1967-71 Chevy and GMC Trucks, and 1967-70 Dodges and Plymouths (again, each set of applications shows a different Master Cylinder assembly number). Thus, besides possible internal differences, there are likely physical differences in mountings and in tube nut sizes.
So, a "word for the wise" ; if taking Richard's suggestion, "If you are ONLY needing the seats, you may still be OK", just be sure you have a known 1967 Mustang Disk Brake MC with which to compare, and even more importantly, if you don't have an original, and are seeking one, be sure that it came from a 1967 Mustang. At least through 1968, the Power Drum and Power Disk Brake Master Cylinders were all "unique" to 1967 Mustangs, all carrying a C7ZZ Part Number, and the Manual Drum MC being unique with a C7ZZ Part Number until January 9, 1967, at which time it was replaced by C7AZ-2140-M.
Hope this will help some from ending up with incorrect parts.
Bob
MCA 04909
« Reply #25 on: March 10, 2018, 03:38:04 PM »
To add to the discussion, the identification of a 67 and many 68 Mustang disc brake master cylinders can be done by observing the stop bolt. It is typical to see on 67 and many 68 Masters a small hex head stop bolt underneath vs the cone shaped stop bolt of later years.
Offline 196667Bob
« Reply #26 on: March 10, 2018, 03:54:01 PM »
+1 And, also on the Drum Brake Master Cylinders.
Bob
MCA 04909
Offline 67350#1242
« Reply #27 on: March 10, 2018, 08:54:04 PM »
According to the 1967 Shop Manual the factory master cylinders had a code letter stamp on the side or on the end for easy service identification.   For Mustang/Cougar power disc code M,  power drum code X, standard drum code T.
See shop manual brake section pp 2-9 thru 2-11 and Fig. 3.
My 67 GT350 has its original and there is an M stamped on the forward end.
Kurt
67 GT350 SJ 2/01/67
1967 eight barrel
  • Guest
« Reply #28 on: March 10, 2018, 11:04:59 PM »
The bore of the power Disc/Drum Vs. Drum/Drum is different. 1/16" larger on the Disc/Drum. That solves that...
Offline mtinkham
  • That'll be easy
« Reply #29 on: December 14, 2023, 02:07:42 PM »
This is an old post but applicable to my issue...I ordered a master cylinder rebuild kit from NPD this week (12/11/2023) and did not receive the check valves nor the seats. Application is 1967 Mustang, Power Disc Brakes. Kit I ordered was 2004-4...no one seems to have the MK549 kit.
Anyone have a source for these items (seats and check valves)?
